Pocster Posted October 23, 2020 Posted October 23, 2020 Googled this but couldn’t find anything . I thought it would be really good to trigger my Mvhr to boost on water flowing for certain items . So a ‘device’ clamped on the shower feed Hep2o pipes , or maybe on the toilet feed . So when in use I can trigger a relay to boost mvhr . I know I could go off motion but I’m trying to be more specific- as I have a manifold of manifolds it makes access easier .
SteamyTea Posted October 23, 2020 Posted October 23, 2020 There are ultrasonic sensors that are non-invasive for water pipes. https://www.omega.co.uk/prodinfo/ultrasonic-flow-meters.html Look for something cheaper though. You may find that a couple of temperature sensors set up differential may work. 1
Pocster Posted October 23, 2020 Author Posted October 23, 2020 7 minutes ago, SteamyTea said: There are ultrasonic sensors that are non-invasive for water pipes. https://www.omega.co.uk/prodinfo/ultrasonic-flow-meters.html Look for something cheaper though. You may find that a couple of temperature sensors set up differential may work. Perfect! Until I saw the price !! I suppose an inline Hep2o one would be nice and cheaper !! Shall investigate ! . I reckon it’s the type of thing @Onoff would love to make .... ?
Pocster Posted October 23, 2020 Author Posted October 23, 2020 Found some on eBay for £10 Certainly not clear exactly how they work - I presume it’s just a relay . Stick a current down it and if there’s flow ;circuit is complete ... . Worth a look at later - then I can bill SWMBO when she fills the bath up !
SteamyTea Posted October 23, 2020 Posted October 23, 2020 Just now, pocster said: Found some on eBay for £10 Certainly not clear exactly how they work - I presume it’s just a relay . Stick a current down it and if there’s flow ;circuit is complete ... . Worth a look at later - then I can bill SWMBO when she fills the bath up ! Put the link up
Pocster Posted October 23, 2020 Author Posted October 23, 2020 1 minute ago, SteamyTea said: Put the link up Ok Why aren’t you working ? - just reading my crap . https://www.ebay.co.uk/itm/Water-Flow-Plastic-Switch-Vertical-Horizontal-Water-Sensor-Magnetic-AC-220V-New/184082673729?hash=item2adc2eb041:g:jaQAAOSwKFlfhJlk
joe90 Posted October 23, 2020 Posted October 23, 2020 Why not use a RH sensor in the extract duct like most do.
Pocster Posted October 23, 2020 Author Posted October 23, 2020 22 minutes ago, joe90 said: Why not use a RH sensor in the extract duct like most do. There’s a sensor on the mvhr . As I haven’t used it yet I was concerned how long it takes before it activates . Just thinking ahead ?
Onoff Posted October 23, 2020 Posted October 23, 2020 1 hour ago, pocster said: Googled this but couldn’t find anything . I thought it would be really good to trigger my Mvhr to boost on water flowing for certain items . So a ‘device’ clamped on the shower feed Hep2o pipes , or maybe on the toilet feed . So when in use I can trigger a relay to boost mvhr . I know I could go off motion but I’m trying to be more specific- as I have a manifold of manifolds it makes access easier . I think it was a couple of years ago I was mulling a flow switch placed in line to the rainfall shower head. It would trigger a ring of LEDs set in a circular pattern around the shower head...maybe in a like Knightrider sequence. To get the full effect I need the noise from the Stargate transporter rings. https://youtu.be/eXc36FwY4zQ
Pocster Posted October 23, 2020 Author Posted October 23, 2020 1 minute ago, Onoff said: I think it was a couple of years ago I was mulling a flow switch placed in line to the rainfall shower head. It would trigger a ring of LEDs set in a circular pattern around the shower head...maybe in a like Knightrider sequence. To get the full effect I need the noise from the Stargate transporter rings. https://youtu.be/eXc36FwY4zQ And why didn’t you do that ? ?
Temp Posted October 23, 2020 Posted October 23, 2020 Perhaps something like this (it not a clip on though. You need to cut pipe).. £29 https://www.amazon.co.uk/Flow-Switch-15mm-0-5l-min/dp/B0091GOKZ0 same for £18.. https://cpc.farnell.com/sensor-solutions-te-connectivity/fs-10/flow-switch-15mm-0-5l-min/dp/SN36477 1
Onoff Posted October 23, 2020 Posted October 23, 2020 1 minute ago, pocster said: And why didn’t you do that ? ? Other people thought is was a silly idea, along with the rise and fall shower head. As your mate said "The people who are crazy enough to think they can change the world are the ones who do". 1
Pocster Posted October 23, 2020 Author Posted October 23, 2020 5 minutes ago, Onoff said: Other people thought is was a silly idea, along with the rise and fall shower head. As your mate said "The people who are crazy enough to think they can change the world are the ones who do". Then stop fecking about and do it this weekend ?
SteamyTea Posted October 23, 2020 Posted October 23, 2020 Put in some really powerful UV LEDs, that will kill all the germs. And like all boys in the shower, spending too long in there 'washing', will make you blind. 1 1
joe90 Posted October 23, 2020 Posted October 23, 2020 1 hour ago, pocster said: There’s a sensor on the mvhr . As I haven’t used it yet I was concerned how long it takes before it activates . if I jump in the shower mine comes on within two minutes, only problem is the ambient RH sometimes confuses it, @Jeremy Harris said he adjusted his winter to summer. 1
Onoff Posted October 23, 2020 Posted October 23, 2020 1 hour ago, SteamyTea said: Put in some really powerful UV LEDs, that will kill all the germs. And like all boys in the shower, spending too long in there 'washing', will make you blind. Like the bottoms of milk bottles my glasses!
Onoff Posted October 23, 2020 Posted October 23, 2020 1 hour ago, pocster said: Then stop fecking about and do it this weekend ? Be worth it just for my lads reaction when he comes back from uni. Big Stargate fan he is. 1
