got response eventually from planning  and maybe \\\\\\\\\i will need to keep lower level of orginal granite house
 so my intial thoughts are stabilize it all -- put a ring beam on top of first floor -then concrete roof  and build modern house on top
  thinking it could be alot cheaper than having masons in messing about to do the same thing
open to any other suggestions  that will not take off too much interior space
maybe shutter it all and a thin  sloppy concrete wall ?
 or use something like VELOX panels to do the same ?
 think that could be cheaper than flatten and the rebuild original outer facade  on to an ICF or block wall
 now the head will really start to spin
Was suggested to me for stabilising a river wall.  It was a similar cost to formwork in the end and the finish was not what I was after.
9 minutes ago, scottishjohn said:
what is that exactly
I have seen it used for tunnels as well.
Seen it done to build a swimming pool
sprayed it on, high pressure 30-40mm hose, small stones in the mix
one man spraying, one holding the hose behind him as it kicks a bit, then they let it go off for half an hour and scrape it back flat.
