September 21, 20206 yr Hi everyone. I'm looking for recommendations for a SE for our ICF build in Hampshire. Looking for a SE who is cost-conscious and not addicted to sticking unnecessary amounts of steel and concrete into the ground.
September 21, 20206 yr 7 minutes ago, Piers said: Hi everyone. I'm looking for recommendations for a SE for our ICF build in Hampshire. Looking for a SE who is cost-conscious and not addicted to sticking unnecessary amounts of steel and concrete into the ground. what ICF system ? they don,t all need lots of rebar except for round opening- uk is not earth quake zone check out Istoex they offer services like that as part of their services-just give them the plan
September 21, 20206 yr An SE for which aspect of ICF? As I understand it the ICF suppliers have their own SEs, so that would be a good starting place. Ours, Tanners, was excellent. We built with Durisol.
September 21, 20206 yr Author 2 hours ago, scottishjohn said: what ICF system ? Undecided. Between Isotex and Durisol. 1 hour ago, ToughButterCup said: An SE for which aspect of ICF? To include foundations, retaining walls (sloping site), and the usual openings, lintels, etc Edited September 21, 20206 yr by Piers
September 21, 20206 yr 25 minutes ago, Piers said: To include foundations, retaining walls (sloping site), now you just made it non standard mentioning retaining walls,etc so yes you will need an SE --but surely best to use the design the maker of your chosen ICF system suggests
September 21, 20206 yr 1 hour ago, Piers said: Undecided. Between Isotex and Durisol. To include foundations, retaining walls (sloping site), and the usual openings, lintels, etc Then give Tanners a ring; competent, straight sensibly priced.
September 21, 20206 yr Author 2 hours ago, scottishjohn said: surely best to use the design the maker of your chosen ICF system suggests I want to examine all my options. Re: foundations - I know it's possible to use ICF underground but want to understand whether we should use it. There's lots to consider with quite a few variables. One major concern is how to keep the basements dry and the choices we have in keeping water out and diverting it around the building (tanking, waterproof concrete, etc)
September 22, 20206 yr 9 hours ago, Piers said: I want to examine all my options. Re: foundations - I know it's possible to use ICF underground but want to understand whether we should use it. There's lots to consider with quite a few variables. One major concern is how to keep the basements dry and the choices we have in keeping water out and diverting it around the building (tanking, waterproof concrete, etc) I will be very surprised if building control accept anything but tanking and french drains- this is why you need a design - what you want and and what BC will accept could be totally different there are no extra problems using ICF for basements than any other system and you already have said you are wanting keep concrete and steel down -- you will not find the full solution for free no matter how long you study the net pick a system an SE and an architect professional fees are part of the cost with a tricky site you already have all the info you get for free already -by what you have said people who make your chosen system must be the ones to be at front of your design process --they will know cheapest way to build what you want I think an architect who does not know system will cost you money and delays If site is really tricky then you may need to spend some money on ground survey -to see if it will take what you want to do if its soggy --maybe it will have to a different system all together or spend large amount of very deep foundations sounds like you come to the end of the guessing game road and now need to spend on ground surveys and professionals then maybe you can decide what system you will use to build your house -- have you bought the plot yet?
September 22, 20206 yr You will need a soil survey. With ICF you cannot see the concrete so you will not know if it has faults or voids. Type C internal drained cavity membrane with sump and pumps is considered the lowest risk for basement waterproofing.
September 23, 20206 yr Using Durisol blocks on 2 builds here, the sumps for the basement are shown here. Our SE was not aware of this type of build but she has certainly risen to the challenge. Crystal Engineering, Kirsty Hudson. Lots of rebar for the basement as we are set in a hill, sumps took some head getting around but no 2 went far quicker than no 1.
