Buy or build a house ?
Dos
I have absolutely no clue or any knowledge about self-build whatsoever.
After trying to buy a house over the past year and failing miserably, I'm considering the possibility of a self-build. We're thinking of buying a building plot in the west country and having a simple conventional brick and tile two bed detached bungalow / house built. Budget would be around £180 with a small mortgage.
Can you obtain pre-designed plans or is that option fraught with disaster (planning etc).
Is it feasible, or would I be better off persisting with the estate agents to find what I'm looking for?
Does your £180k budget include purchase of the plot?
Most plots come with physical constraints i.e. awkward narrow shape, difficult road access, neighbours whose privacy must be respected to obtain planning permission, a steep gradient, trees with wicked root systems or dodgy ground. Given your budget you would be lucky to find a plot onto which you can plonk an off the shelf design.
eps
You have just described our plot ?
I'm afraid it does :(
But that's why I posed the question. I wanted to be let down lightly before an idea became a dream, and my finances decided I was having a nightmare. It looks like I'm back to dealing with estate agents, followed by long conveyancing chains to find that 1960s bungalow has poor insulation with rusting brick ties and woodworm in the attic.
Bugger.
Bugger.
Welcome and good luck!
What area are you looking? I have been looking for that bungalow around west Yorkshire for quite some time and i have your entire budget to spend on it ... admittedly i do want a larger plot but i would welcome a difficult site and poor access etc.
Devon, Cornwall or at a push Lincolnshire fens (the fens are flat as a pancake, so the plot should be less of an issue (apart from the usual peat and clay issues), plus Lincs is cheap for housing at present).
what about a compromise for a few years-- buy a wreck -and do it up --yourself and sell at profit -then maybe look again -or maybe it will take a couple of diy rebuilds to get the funds you want to buy what you want -
or buy correct plot ,get planning  and start a build hwile living in a big caravan  and save up over next year or two
Icould be wrong - but 180K for plot and new house in west country sounds impossible to me- 180 k for  the house if built economically
If I were decades younger, I'd be all over that ideal like a rash.
I have looked into auctions, but the price they sell for -even the real bad ones- are not that far of the open market price. I'm not sure  if Covid has screwed things up, or my expectations need keeping in check (I think its the latter! ).
There is Cornwall. And then there is Cornwall.
Are you only after a bungalow?
Quick look on the Land Registry shows 2 detached properties below 180k that have sold recently, one in Illogen Downs and the other in St. Day.
Probably more about but picked places by the A30.
Edited by SteamyTea
