Mooruk Posted August 1, 2020 Posted August 1, 2020 (edited) We have a 50 year old brick-built septic tank. Having uncovered the top of it from many years of earth and roots, we found the tank to have a hole (120mm diameter) for a long gone vent pipe and at the opposite end a vent pipe that is crumbling away. The question is what is the best thing to use for venting? I've seen this https://www.amazon.co.uk/dp/B00FQEX1ZG/ref=cm_sw_r_cp_apa_i_PIujFbFC28WP4 (Studor Maxi-Filtra Two Way Vent for Septic Tank) can I use this for both holes or sold I use on of plus an Air Admittance Valve on the other? Can send pics if necessary. Thanks in advance Edited August 1, 2020 by Mooruk change format
Russell griffiths Posted August 1, 2020 Posted August 1, 2020 Is it close enough that smells will be annoying, if not they normally just vent to the atmosphere via a 110mm pipe with a bird proof cone on top.
Nickfromwales Posted August 1, 2020 Posted August 1, 2020 Is there a vent to atmosphere on the house? If so that should be suffice. You can vent low level from the tank at the boundary too, if it won’t be a nuisance to neighbours. Or, at a garage / outbuilding. Put a paving slab over the one at the tank and redo the one travelling away?
Mooruk Posted August 1, 2020 Author Posted August 1, 2020 2 hours ago, Russell griffiths said: Is it close enough that smells will be annoying, if not they normally just vent to the atmosphere via a 110mm pipe with a bird proof cone on top. Our garden isn't massive, so ideally we don't want to smell it at all.
Mooruk Posted August 1, 2020 Author Posted August 1, 2020 Thanks for the advice, here's a pic of it to help.
joe90 Posted August 1, 2020 Posted August 1, 2020 +1 wot @Nickfromwales said above, my treatment plant is only vented to atmosphere away from the plant on the side of my garage past the house.
Onoff Posted August 1, 2020 Posted August 1, 2020 Similar to ours I guess. Inspection manhole in the foreground then the lid of the tank:
Nickfromwales Posted August 1, 2020 Posted August 1, 2020 5 hours ago, Mooruk said: Thanks for the advice, here's a pic of it to help. Should have tidied up before the photos tbh, that looks like a shithole.
Onoff Posted August 2, 2020 Posted August 2, 2020 17 hours ago, Mooruk said: Thanks for the advice, here's a pic of it to help. The top looks in better nick than mine, also weed and root covered. I did debate casting a reinforced slab on top. You have I think two chambers...wondering if I have now but it'd mean hacking further into the jungle! Is it brick built, like a beehive in shape? I attempted a video inside ours by just leaning in.
Mooruk Posted August 3, 2020 Author Posted August 3, 2020 We did actually have three chambers, one was a leeching pit that acted as a soakaway. However, the roots had completely gone through the perforated bricks so rendered it useless. Now we've had a pipe fitted from the second chamber to a pumping station to soakaway in our garden.... (Which is too small for a standard soakaway.....) Learnt a lot in the last few months!
