NewToAllOfThis Posted July 28, 2020 Posted July 28, 2020 We are have Beam and Block on A steel Beam and a timber frame building. The Frame provider has recommended blocks of 140mm sat on 10mm of mortar creating 150mm height. Then using 90mm of insulation and 60mm of screed. We are not having underfloor heating, is this a sensible buildup of insulation and screed? Are 140mm blocks available or would they need to be cut to size. Looking for suggestions and information as to what others have done
scottishjohn Posted July 28, 2020 Posted July 28, 2020 (edited) surely your blocks must be same depth as the beams? a picture of your suggested build of floor please this detail surely is noted on your plans Edited July 28, 2020 by scottishjohn
Russell griffiths Posted July 28, 2020 Posted July 28, 2020 I wouldn’t think 90mm of insulation even gets to building regs does it.
Mr Punter Posted July 28, 2020 Posted July 28, 2020 3 minutes ago, Russell griffiths said: I wouldn’t think 90mm of insulation even gets to building regs does it. Probably above the minimum threshold but will need to make up elsewhere and floor insulation is simple to fit, just chuck it down. 120mm Celotex would work.
Declan52 Posted July 28, 2020 Posted July 28, 2020 You can get 150 x100X 440mm blocks. https://stowellconcrete.co.uk/concrete-soap-bar-blocks/
NewToAllOfThis Posted July 28, 2020 Author Posted July 28, 2020 (edited) Thanks for the replies so far, so if I need more than 90mm of insulation what is the next size of brick after 150mm. Without underfloor heating what is the sensible thickness of Screed Edited July 28, 2020 by NewToAllOfThis
