Thedreamer Posted July 25, 2020 Posted July 25, 2020 Would anybody be able to recommend a company that produces signs for a house name? So many when I googled. Going to be mounted on a gate
nod Posted July 26, 2020 Posted July 26, 2020 We used this company (EBay) Excellent quality Great communication
Onoff Posted July 26, 2020 Posted July 26, 2020 16 minutes ago, nod said: We used this company (EBay) Excellent quality Great communication Did you pay up front or stick it on the slate? 4
Temp Posted July 26, 2020 Posted July 26, 2020 There are lots online. Many have standard sizes and the aspect ratio of your house name may not suit the aspect ratio of the standard dimension. I recommend printing it out life size to check it looks ok and that the font is big enough to actually read from the road. I used a company called Slatework Signs.. Slateworksigns.co.uk
Ferdinand Posted July 26, 2020 Posted July 26, 2020 (edited) 8 minutes ago, Temp said: There are lots online. Many have standard sizes and the aspect ratio of your house name may not suit the aspect ratio of the standard dimension. I recommend printing it out life size to check it looks ok and that the font is big enough to actually read from the road. I used a company called Slatework Signs.. Slateworksigns.co.uk You should be able to adjust the aspect ratios of the font by up to 15% each way without detriment using stretching or kerning horizontally or tracking vertically if several lines, or just switch your font. Those were the sort of adjustments which were possible when I used to design publications (though 7-10% was better). So I think that should be manageable, depending on how much control you get. Edited July 26, 2020 by Ferdinand 1
nod Posted July 26, 2020 Posted July 26, 2020 3 hours ago, Onoff said: Did you pay up front or stick it on the No nothing to do Just drill four corresponding holes
Redoctober Posted July 26, 2020 Posted July 26, 2020 @Thedreamer We got ours from a company advertising on Etsy.com - about £30 if I recall correctly. 1
Thedreamer Posted July 26, 2020 Author Posted July 26, 2020 8 hours ago, nod said: We used this company (EBay) Excellent quality Great communication Who was the seller?
Thedreamer Posted July 26, 2020 Author Posted July 26, 2020 6 hours ago, Ferdinand said: I use my local monumental mason. I would imagine that would look smart and last a long time. 1
Thedreamer Posted July 26, 2020 Author Posted July 26, 2020 6 hours ago, Temp said: There are lots online. Many have standard sizes and the aspect ratio of your house name may not suit the aspect ratio of the standard dimension. I recommend printing it out life size to check it looks ok and that the font is big enough to actually read from the road. I used a company called Slatework Signs.. Slateworksigns.co.uk Thanks Temp had a look at the link but I think they had shut down for a bit.
Thedreamer Posted July 26, 2020 Author Posted July 26, 2020 2 hours ago, Redoctober said: @Thedreamer We got ours from a company advertising on Etsy.com - about £30 if I recall correctly. Thanks RedOctober. The house name is now registered, we just paid that annoying fee. We share a similar name. Druim nan Darach
nod Posted July 26, 2020 Posted July 26, 2020 16 minutes ago, Thedreamer said: Who was the seller? Personalized Granite ebay 1
Ferdinand Posted July 26, 2020 Posted July 26, 2020 (edited) Can you get a Secondhand one from ASDA? Or various politicians? Edited July 26, 2020 by Ferdinand
Thedreamer Posted July 26, 2020 Author Posted July 26, 2020 1 hour ago, Ferdinand said: Can you get a Secondhand one from ASDA? Or various politicians? Nearest Asda is three hours away and I thought that Ed Miliband retired but now he is back.
