I wish one day to have an electric car .
There’s a multitude of different chargers , but as I don’t have the vehicle nor the charger I can’t select anything .
Presumably it’s just a meaty cable off the consumer unit to the charger ?
To future proof what’s the meatiest cable I could put in even if it’s overkill ? ??
Edited by pocster
Maximum single phase charger is 7Kw from memory so 10mm is what they seem to specify. Can you not get near the meter as ideally you should not run this via the CU
I still think we are at the VHS / Betamax stage with car chargers.  I do hope one day there will be be one standard charger?
  • Haha 1
23 minutes ago, pocster said:
Sorry you’ve lost me . Surely it runs from the CU or some big ‘trip’ ?? ?
They suggest you don't run large loads for long periods through a CU - this is a load that runs at full power for hours.
Ah I see !
what's the logic behind that? Surely the charger's supply needs protection and and MCB is an MCB whether it's in the main CU or another box...
