Reiver Posted June 2, 2020 Posted June 2, 2020 So on my mad project idea (pics to be posted when I have accumulated enough info to do a reasonable 3D rendering) I have a couple of curved section cavity walls, which will need insulating obviously: ideally to at least 125mm if my sums are correct. I'm thinking that EPS beads are the most likely answer, but are there any other technologies that could work I wonder? FYI one section will have a radius of approx 1.5m to the insulation, the other about 2.7m.
Conor Posted June 3, 2020 Posted June 3, 2020 You'd be better off using ICF. Easy to form to curves. If you've a lot of curved / awkward sections, ICF could be more cost effective 1
A_L Posted June 3, 2020 Posted June 3, 2020 10 hours ago, Reiver said: but are there any other technologies that could work I wonder? Supafil loose fill mineral fibre insulation from Knauf:- https://www.knaufinsulation.co.uk/insulation-products/blowing-wool-insulation or Walltite, an injected polyurethane foam from BASF with a low thermal conductivity of around 0.025W/m.K https://walltite.basf.co.uk/
PeterW Posted June 3, 2020 Posted June 3, 2020 I would use EPS bead - quick and easy and can be used everywhere and you won't get joins between insulation types
Reiver Posted June 3, 2020 Author Posted June 3, 2020 Thanks for the suggestions - I will go investigate and price up.
Reiver Posted June 3, 2020 Author Posted June 3, 2020 5 hours ago, Conor said: You'd be better off using ICF. Easy to form to curves. If you've a lot of curved / awkward sections, ICF could be more cost effective Can ICF be "bent" that tight? The inside radius would be something like1.2m - it's a tower for a spiral staircase BTW.
Conor Posted June 3, 2020 Posted June 3, 2020 28 minutes ago, Reiver said: Can ICF be "bent" that tight? The inside radius would be something like1.2m - it's a tower for a spiral staircase BTW. Yes. It's just cut to size/angle like a concrete block. Some manufacturers will provide you with blocks made specifically for your radii. https://becowallform.co.uk/wp-content/uploads/2015/03/building-a-curved-ICF-wall-with-Wallform-350x321.jpg C
