Slab cavity insulation
Ttw
I'm looking at ordering 100mm insulation for a new build annex (100mm cavity)
I've come across Knauf earthwool dritherm 32 and dritherm 37.
The 37 is quite a bit cheaper and wondering if anyone has any advice. I've been told that if using a full slab to go double the thickness of what kingspan would need to be.
7 minutes ago, tonyshouse said:
I used 300mm of r32 May as well do the best you can while you are at it, making sure it all gets installed properly Makes a huge difference too.
300mm in the roof space? Surly not a cavity! I agree with doing the best so there's no regrets
1 hour ago, Miek said:
300mm full fill cavity, gets you to passive standards. That is what I'm about to do also.
Unfortunately I'm not able to build with such a large cavity, what type of building is the one you are talking about using a 300mm cavity?
I used Dritherm 32 in 100mm cavity - if you shop around and buy in bulk you can get good deals.
"Gulp" I just did a quick google - the prices have shot up from last year.
Edited by wozza
Depends how much ££ you have to spend too, and what level of performance you are trying to achieve.
For my upcoming build which has a 100mm cavity, i'm using full fill Xtratherm CT/PIR boards, which are specifically designed to fully fill a 100mm cavity. Kingspan now also do a 90mm Kooltherm board, which gives about the same performance, but requires joints taping, and costs a lot more.
Both of these solutions will give around 0.16U using Celcon type blocks on the inner skin, which is almost passive house target for the walls (0.15U)
I was pretty shocked too, fortunately I only need 50m2
Definitely worth doing right the first time so there's no regr..... I've done that in previous extensions and regret not making it right the first time.
