Ttw Posted May 26, 2020 Share Posted May 26, 2020 I cant get access to next doors or the adjacent property to build my garden room. I'm wondering if it's possible to build it all off the slab within the new build (8mx4m) Im trying to find out if its doable by building the external block work first then using a full fill cavity insulation as I'll not be able to use the original idea of 50mm kingspan. (cavity 100mm) Any advice would be massively appreciated. Link to comment Share on other sites More sharing options...
Russell griffiths Posted May 26, 2020 Share Posted May 26, 2020 (edited) Why not timberframe build the frame on the floor and clad the outside then stand it up you only need to get to the corners to put some corner trim on. Its done like this for a few modular buildings. It can be built overhand, but how are you proposing to weatherproof the block work, 100mm blocks are notoriously porous. Edited May 26, 2020 by Russell griffiths Link to comment Share on other sites More sharing options...
Temp Posted May 26, 2020 Share Posted May 26, 2020 Access for maintenance might be an issue for timber frame. I think blocks usually have to be rendered to make them frost proof as well? What say others? Bricks can be done "overhand" but bricklayers don't like it. Link to comment Share on other sites More sharing options...
Simplysimon Posted May 26, 2020 Share Posted May 26, 2020 timber frame and cavity with cembrit cladding or any other cladding which doesn't need maintenance. 1 Link to comment Share on other sites More sharing options...
scottishjohn Posted May 26, 2020 Share Posted May 26, 2020 7 hours ago, Ttw said: I cant get access to next doors or the adjacent property to build my garden room. I'm wondering if it's possible to build it all off the slab within the new build (8mx4m) Im trying to find out if its doable by building the external block work first then using a full fill cavity insulation as I'll not be able to use the original idea of 50mm kingspan. (cavity 100mm) Any advice would be massively appreciated. why would you build it so close to boundary 500mm+ in and you can just about get to it to build it anyway you choose,and maintain it in future Link to comment Share on other sites More sharing options...
Ttw Posted May 26, 2020 Author Share Posted May 26, 2020 5 minutes ago, scottishjohn said: why would you build it so close to boundary 500mm+ in and you can just about get to it to build it anyway you choose,and maintain it in future Unfortunately my garden isn't of a big enough size to move it in, I'm basically building it the full width of my garden and stepping it forward enough to get a fence up at the rear if required however the neighbours are OK with staring at a block wall however I'll be able to get round with enough space to render or clad it of some sort. It just seems easier to build off the slab. Link to comment Share on other sites More sharing options...
scottishjohn Posted May 26, 2020 Share Posted May 26, 2020 7 minutes ago, Ttw said: Unfortunately my garden isn't of a big enough size to move it in, I'm basically building it the full width of my garden and stepping it forward enough to get a fence up at the rear if required however the neighbours are OK with staring at a block wall however I'll be able to get round with enough space to render or clad it of some sort. It just seems easier to build off the slab. think about the fance maybe you can make post holes you drop the fance into fater you built it? If not i would make it smaller to get trhe space --your call Link to comment Share on other sites More sharing options...
