I’ve got four Youngerman boards where the plywood working surface is worn out. The surface appears to be 9mm phynolic plywood (dark brown in colour and resin bonded). I’ve tried locally to get a few sheets and failed. Most BMs appear to be limiting their range of products as made things easier in these difficult times. Can anyone suggest a reputable online supplier?
Yes, talked to them, they buy in bulk and it’s all thick stuff,  20mm and thicker. Phoned their supplier and the thinnest they do is 18mm. I need 9mm!
won,t wear out at 18mm --
4 minutes ago, Russell griffiths said:
But twice as heavy.
my guess the 9mm is osmething made to order for them
18mm or thicker is whats usually used for truck and trailers
 3mm alloy checker plate on top of it?
Edited by scottishjohn
