ProDave Posted May 21, 2020 Posted May 21, 2020 Fitting the en-suite bathroom now. Had a slight problem with one sheet of multipanel that despite being templated needed a bit of adjustment. The result of that is the hole for the shower outlet had to be enlarged slightly. So now the hose outlet fitting I have does not quite cover the hole. so I need a larger one. This is like the one I have. The flange that touches the wall is 45mm diameter https://www.ebay.co.uk/itm/Keenware-KSA-003-Brass-Shower-Wall-Elbow-Outlet-Round/153689371778?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D225114%26meid%3D16e9edb5c6bf458a8cec18299a196493%26pid%3D100005%26rk%3D2%26rkt%3D12%26mehot%3Dpf%26sd%3D114199202223%26itm%3D153689371778%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv5PairwiseWebWithBBEV1Filter&_trksid=p2047675.c100005.m1851 I have found this one that would do, it's 60mm diameter. BUT it's plastic. I really want a proper sold brass one. https://www.ebay.co.uk/itm/Shower-Outlet-Supply-Elbow-75-x-60-x-35mm-Chrome-60mm/171729719523?hash=item27fbe390e3:g:KakAAOSwEeFVD8y7 I have also found this one https://www.ebay.co.uk/itm/184167866578 That does not state the size. I have messaged the seller and waiting for an answer from him. In the mean time any other ideas? I think I need at least 55mm diameter, 60 would be more comfortable and I really want solid brass not plastic.
MikeGrahamT21 Posted May 21, 2020 Posted May 21, 2020 (edited) How about this: https://www.ebay.co.uk/itm/HANSGROHE-Fixfit-S-Wall-Outlet-27453000/143313828432 Looks like its a brass (or some type of metal) fitting with a plastic cover, and a non-return valve. Edited May 21, 2020 by MikeGrahamT21
ProDave Posted May 21, 2020 Author Posted May 21, 2020 Possibly, but oh the price, I had not gone that far down the list.
PeterW Posted May 21, 2020 Posted May 21, 2020 10 minutes ago, ProDave said: Possibly, but oh the price, I had not gone that far down the list. So how much is a replacement Multipanel ..? Isn't that the other option..?
MikeGrahamT21 Posted May 21, 2020 Posted May 21, 2020 (edited) ? £25 for a good finish is worth it surely? Theres some more on ebay, cheapest is £22.80 Edited May 21, 2020 by MikeGrahamT21
Temp Posted May 21, 2020 Posted May 21, 2020 (edited) Dimensions are about right.. https://www.amazon.co.uk/gp/aw/d/B07Z67Y9MG/ref=sspa_mw_detail_1?ie=UTF8&psc=1 Says brass but is it all brass or part plastic? Ask? Edited May 21, 2020 by Temp 1
ProDave Posted May 21, 2020 Author Posted May 21, 2020 50 minutes ago, Temp said: Dimensions are about right.. https://www.amazon.co.uk/gp/aw/d/B07Z67Y9MG/ref=sspa_mw_detail_1?ie=UTF8&psc=1 Says brass but is it all brass or part plastic? Ask? A big thank you. That looks just like the one I have only the flange part (which is a separate part) is a larger diameter and will cover my bodged hole. Just off to order it. EDIT: only after ordering it and looking at the expected delivery date, do I find it's coming from China. Amazon don't seem to make that as clear as Ebay.
Onoff Posted May 23, 2020 Posted May 23, 2020 How about a bfo stainless "washer" with an outside diameter of what you want to cover the bodge? Starrett one? Polishing to mirror finish would be a git. Or a chrome plated brass tap base ring e.g: https://www.bathroomspareparts.co.uk/tap-shrouds--base-rings-2192-c.asp
ProDave Posted May 23, 2020 Author Posted May 23, 2020 I have fitted the one I have for now leaving the edge of the butchered hole on show and will swap it for the Chinese one when it arrives.
