soapstar Posted May 3, 2020 Posted May 3, 2020 (edited) Hey Folks, Needing some advise on the construction of our planned integrated double garage which has one wall attached to the utility room. It was originally planned to have what I believe is called a 'double skin' construction, from what I can gather this is basically external brick with a cavity gap and another brick wall internally. However I have been informed there is another option to have either a single skin construction (one layer of brick?) or a single skin with a studded internal wall. The latter seems to provide better insulation etc and also the added benefit of a cavity for cables etc - is it more common practise to have a studded internal wall for an integrated garage or is a double skin construction still used? Any examples from your own builds would be greatly appreciated! Cost comparison would be great also! Thanks.? Edited May 3, 2020 by soapstar
nod Posted May 3, 2020 Posted May 3, 2020 Not for my own build But most show houses are done this way I’ve studded out a number of garages to be used as a sales centre 50 metal stud 15 off the wall with 50 sound insulation Plaster-boarded and taped or skimmed The sales people are often in there for quite a long time with building going on around them
Adam2 Posted May 3, 2020 Posted May 3, 2020 Interested in this as also planning the garage structure - it's attached to the house (well will be when we build something) but will never be a habitable space or built above so wondering what is most appropriate - like above single skin brick or a single skin larger block as will be rendering the outside or is this a bit flimsy? Will have a mono-pitch timber roof with single ply membrane so that's not very heavy.
soapstar Posted May 4, 2020 Author Posted May 4, 2020 Thanks @nod I guess my biggest question is what are the determining factors in deciding on what type to build? correct me if I’m wrong anyone however from what I believe if it’s a double skin it would be harder to convert this garage into another liveable room in the future? For further information we have planned a timber frame pitched roof as with the rest of the house.
nod Posted May 4, 2020 Posted May 4, 2020 22 minutes ago, soapstar said: Thanks @nod I guess my biggest question is what are the determining factors in deciding on what type to build? correct me if I’m wrong anyone however from what I believe if it’s a double skin it would be harder to convert this garage into another liveable room in the future? For further information we have planned a timber frame pitched roof as with the rest of the house. We have double skinned our detached garage If it was ever used as say an office We could simply blow insulation into the cavity
soapstar Posted May 4, 2020 Author Posted May 4, 2020 10 minutes ago, nod said: We have double skinned our detached garage If it was ever used as say an office We could simply blow insulation into the cavity Thanks @nod Cost wise what would your opinion be between double skinned or studded walls?
MAB Posted May 5, 2020 Posted May 5, 2020 (edited) I built my integrated garage to the same standard of construction and insulation to walls and roof as the rest of the house, a minimal cost difference in the scheme of things, that way the garage can always be used in the future for extra living space or as a warm Hobby room/Gym/Workshop, etc with minimal conversion work. Also a good selling point if you ever move on as few people seem to use a garage for a car anymore..... Edited May 5, 2020 by MAB 1
Russell griffiths Posted May 6, 2020 Posted May 6, 2020 Mine is built to the same standard as the rest of the house icf walls all around 270mm of insulation in the roof 200mm in the floor, if it ever needs converting to a granny flat or something it’s 90% ready. But it will make a nice place as a workshop. 1
