Currently considering which sewage treatment plant to install and am considering a Vortex Eco.  The manual says:
DON’T allow the condensate from heating systems to enter the foul drains. This has a very low pH and can destroy a sewage treatment plant or septic tank.
The MVHR unit I have, a Vent-Axia Kentic Plus, has a condensate drain that the install manual states:
The unit’s condensate drain must be connected to the building’s wastewater drainage system.
Questions:
How much condensate is generated and is it really incompatible with a sewage treatment plant?
Any issues with running the condensate direct to the rain-water drainage system instead?
Its fine - this refers to gas condensing boilers as their condensate is acidic. MVHR is just water either off the heat exchanger or rainwater.
That's a good warning about the condensate drain from a BOILER, but as already stated it would not apply to condensate from an mvhr unit.
