Hi, I need to replace one of these pieces, mainly the piece which is in the middle above the fancy bit ?
Any advice where to get it from would be helpful too.
 Thanks
Try an architectural salvage company.
Heres a list of our local ones - if you hint at your location  in your profile, we'd be able to help you by suggesting sites local to you.
( Click on your Profile image - currently the green letter D - and edit you profile - top right> Edit Profile)
It looks like a terracotta or brick decorative moulding. Moulding is probably one word you can start from.
Take one to a salvage yard, and say “this”.
If there are lots of those on houses in your locality, then someone local should have one.
May be worth gossiping down the street to see if anyone has a spare.
Really need a wider piccie.
Edited by Ferdinand
  • 3 weeks later...
