We're going to make our raised beds soon from tanalised timber 'sleepers' and I'm looking at the hex head bolts used to attach them.  Prices range enormously - from just over £5 for 10 at Wickes, to £16 for 10 of Titan brand.  Is there a happy medium? Are the Wickes ones just as good?  I'm going to need a couple of hundred of these by the time I'm done, so the price differential is significant.
Any suggestions?
Yes, had a look on Ironmongery but couldn't see anything comparable there.  I'll check again, as they have proven to be very good throughout the build for fixings.
Try screwing one into a sample bit of wood before doing it for real. I found I sheared off some bolts if I didn't drill pilot holes. Something like M3.5 maybe enough. Long bits are available.
Ideally the screws should be long enough so the threaded part is only in the lower bit of wood. If the threaded part bridges the gap between the two it may prevent the two bits of wood pulling together. Sorry if you know this stuff.
