Tools for Tiling
ToughButterCup
I last did some tiling when I was about 10 years old - way back last century.
Got at least 50 square meters to lay: I have a strong feeling I'm going to enjoy this part of the build - tiling appeals to me.
List of tools needed please -
really fancy one of those Bosch tiling lasers......?
The most important tool is quality knee pads. They will save you a lot of aches and pain.
As far as proper tools your going to need something to cut the tile. A dry tile cutter will cut most of what you need. You could hire a wet cutter if you have lots of fiddly bits around doors etc or even use an angle grinder.
A tape, a few pencils, chalk line and your nice new shiny laser will help you in setting out your pattern.
Notched trowel and float, a few large buckets for mixing your adhesive and grout. If you have a good high speed drill you can buy a mixer attachment to mix your adhesive.
Depending on how confident you are in doing the tiling then you might look at one of the tile leveling systems.
Things you already I hope own are a long spirit level, sponges, gloves and depending on the size and type of your chosen tile maybe a rubber mallet to tap the tile down.
And not forgetting a good radio so you can sing away and annoy everyone else in the house.
2 minutes ago, Declan52 said:
Google tile leveling systems and there is a vast array of different products all designed to stop you ending up with tiles not sitting flush at the edges.
definatley reccomned them -for we people that don,t do it as a job ,especially when doing large format tiles.
Decent wet tile cutter such as a Rubi bench that will take your biggest tile at 45 degrees.
Set it up in the garden under a gazebo, hose nearby so you can clean it down daily, and change the water in the tank regularly.
If you were closer you could borrow my big one takes 600mm tiles-with a stand as well#don,t think you want to travle this far twice?
Good quality cutter Sigma
Forget tile saws Four inch grinder a pack of diamond blades
Turbo diamond blade 1 mil for fine cuts
Rubber float for grouting
Gauging trowel
6 -12 mil square notched trowels
Rubi
Rubber mallet
600 level
2000 level
Square
Tile file
Fine pencils
OH A bag ?
