ToughButterCup Posted January 9, 2020 Posted January 9, 2020 I last did some tiling when I was about 10 years old - way back last century. Got at least 50 square meters to lay: I have a strong feeling I'm going to enjoy this part of the build - tiling appeals to me. List of tools needed please - really fancy one of those Bosch tiling lasers......?
Declan52 Posted January 9, 2020 Posted January 9, 2020 The most important tool is quality knee pads. They will save you a lot of aches and pain. As far as proper tools your going to need something to cut the tile. A dry tile cutter will cut most of what you need. You could hire a wet cutter if you have lots of fiddly bits around doors etc or even use an angle grinder. A tape, a few pencils, chalk line and your nice new shiny laser will help you in setting out your pattern. Notched trowel and float, a few large buckets for mixing your adhesive and grout. If you have a good high speed drill you can buy a mixer attachment to mix your adhesive. Depending on how confident you are in doing the tiling then you might look at one of the tile leveling systems. Things you already I hope own are a long spirit level, sponges, gloves and depending on the size and type of your chosen tile maybe a rubber mallet to tap the tile down. And not forgetting a good radio so you can sing away and annoy everyone else in the house.
ToughButterCup Posted January 9, 2020 Author Posted January 9, 2020 19 minutes ago, Declan52 said: [...] you might look at one of the tile leveling systems. [...] Que? Is there a German one??
joe90 Posted January 9, 2020 Posted January 9, 2020 Make sure you read threads about tiling! (Only saying after my kitchen tiles all lifted because I didn’t back butter the tiles ?)
Declan52 Posted January 9, 2020 Posted January 9, 2020 Google tile leveling systems and there is a vast array of different products all designed to stop you ending up with tiles not sitting flush at the edges.
ToughButterCup Posted January 9, 2020 Author Posted January 9, 2020 2 minutes ago, joe90 said: [...]I didn’t back butter [...] I dont back-butter my toast either..... 1
scottishjohn Posted January 9, 2020 Posted January 9, 2020 2 minutes ago, Declan52 said: Google tile leveling systems and there is a vast array of different products all designed to stop you ending up with tiles not sitting flush at the edges. definatley reccomned them -for we people that don,t do it as a job ,especially when doing large format tiles.
PeterW Posted January 9, 2020 Posted January 9, 2020 Decent wet tile cutter such as a Rubi bench that will take your biggest tile at 45 degrees. Set it up in the garden under a gazebo, hose nearby so you can clean it down daily, and change the water in the tank regularly. 1
scottishjohn Posted January 9, 2020 Posted January 9, 2020 1 minute ago, PeterW said: Decent wet tile cutter such as a Rubi bench that will take your biggest tile at 45 degrees. Set it up in the garden under a gazebo, hose nearby so you can clean it down daily, and change the water in the tank regularly. If you were closer you could borrow my big one takes 600mm tiles-with a stand as well#don,t think you want to travle this far twice?
nod Posted January 9, 2020 Posted January 9, 2020 1 hour ago, AnonymousBosch said: I last did some tiling when I was about 10 years old - way back last century. Got at least 50 square meters to lay: I have a strong feeling I'm going to enjoy this part of the build - tiling appeals to me. List of tools needed please - really fancy one of those Bosch tiling lasers......? Good quality cutter Sigma Forget tile saws Four inch grinder a pack of diamond blades Turbo diamond blade 1 mil for fine cuts Rubber float for grouting Gauging trowel 6 -12 mil square notched trowels Rubi Rubber mallet 600 level 2000 level Square Tile file Fine pencils OH A bag ?
ToughButterCup Posted January 9, 2020 Author Posted January 9, 2020 34 minutes ago, nod said: [..] OH A bag ? Ooooh, at last ... a chace to get to the January sales and get myself a ManBag. Must get one to match my workboots? Thanks Gary! 1
