Evening all.
I know this was covered recently, but I’m buggered if I can find it.
I will be fitting pir insulation to my ceiling with a batten fitted underneath for cables and to fix the plasterboard to, so the question is how deep should this batten be.
There is a very good chance I will fit downlights so need a batten to cope with shallow lights, how shallow do some of these new led lights go down to.
If the lights are deeper than the batten can I do a recess into the pir insulation?
does that make sense, if a light needed 50mm depth but I had a 25mm batten could I cut a nice neat 30mm deep recess in the pir and line it with foil tape, obviously using a cool running led lamp.
I think mr @Onoff was talking about some shallow lamps.
Real downlights are quite deep. But flat panel LED lights fit in the thickness of a bit of plasterboard, you just need about 25mm for the driver to tuck into.
Do not cut into the PIR.
I have fitted a MF ceiling in my rear extension with a single vaulted roof and also on the second floor extension with a vaulted roof.
The MF gives around me about 75mm of void depth - this includes a small gap to allow cables to pass under the primary channels, so could be about 65mm if placed tight against the PIR.
I will be fitting Aurora Mpro downlights - they only need 47mm depth as the driver can be split from the lamp. I have a fixed version and the adjustable version on trial and I am impressed with them - not the cheapest downlights out there.
https://auroralighting.com/gb/trade/ProductDetail/AU-MPRO1
There are also other offerings from other manufactures that will fit into small spaces -  such Collinwood to name another brand that have the driver fitted at 90 degrees.
Edited by wozza
@wozza can you elaborate on why you don’t like this idea.
I was thinking 70mm pir with a 20mm deep recess covered in the foil tape to bring it back to a fully sealed surface, cut the recess 100mm wider than the light fitting, LED light so low temperature.
Tell me why this is stupid @Onoff @ProDave
What do the manufacturers instructions say ref clearance above the fittings?
I'm thinking Chinese, Indian or possibly cake!
