Hi All,
I need to run the thermostat cables for my UFH ready for Saturday when the fitter arrives to wire it all up and commission the system.
Is 1mm 3 core and earth suitable or should I use 1.5mm 3 core and earth.
The thermostats are Heatmiser Neostat V2
Thanks, Wozza.
Edited by wozza
Hi All,
Thanks for the replies, the instructions are of no help, and I cannot find anything online.
I called the tech line today and asked if I should use 1mm or 1.5mm cable for the Neostat V2 and the chap said  "err 1.5", but he didn't sound very convincing.
So I will use 1.5mm.
No point in 1.5.  In fact I rarely use 1.5 for anything. 1mm 3 core & earth will be fine.
BUT some thermostats are indeed low voltage and use network type cable.
Post a picture of the insides of the thermostat?
7 hours ago, Temp said:
Some Heatmiser stats are 12v and/or use network cable. I've not checked your one.
And there is a 12V version of the Heatmiser Neostat V2 so you do need to check which model you have..
https://www.heatmisershop.co.uk/heatmiser-neostat-12v-v2-programmable-thermostat/?gclid=CjwKCAiAob3vBRAUEiwAIbs5Tn-Te3MoMzR2y6z_2M3buhzhlOTLZfSWAQc0voIdEAtiZSmLUu5c9BoCNoQQAvD_BwE
