Gas oven
36 minutes ago, ProDave said:
Ovens don't actually use much, typically they are 2.3Kw and often do come with just a 13A plug.  But the thorn in the side is fixed heating appliances over 2KW are supposed to be on a dedicated circuit.
I guess an induction hob equally draws little current. Are most electricians qualified to cap the gas so a swap to electric can be made ?
Induction hobs usually draw a LOT more than an oven.
An electrician is not qualified to cap off a gas supply unless he is also gas safe registered.
This pack suggests it’s ok ????
https://www.myappliances.co.uk/prod/Oven-Hob-Packs/art50606-oven-and-hob-pack.htm?gclid=EAIaIQobChMI6YWNuJup5gIVybHtCh0cuwG7EAQYAiABEgJsXPD_BwE
8 hours ago, ProDave said:
13A is 3KW.  Put all 4 rings on and that's 750W per ring available.  I hope you are not in a hurry.
Don't they swap the power between 'rings' when more than two are on.
And isn't it 10A for a continuous load on a socket?
15 hours ago, Temp said:
Nah - don’t like tenants having gas . Gone for electric oven and induction hob - electrician will run a new feed for hob .
  • 1 month later...
To do this properly, contact the gas company and specify who you need to call for your work. Let 3 qualified specialists do it better. I saw a gas explosion indoors, believe me, you don't want it.
Switching to electricity is a good step! Electric stoves and sockets are standard, but check with a consultant or electrician to find out which sockets will work. Every rule has an exception, so it's better to ask specialists than to overpay later.
