Pocster Posted December 9, 2019 Posted December 9, 2019 Hey all Do gas ovens have fans ? IMG_0441.MP4
Pocster Posted December 9, 2019 Author Posted December 9, 2019 Actually ! Can I replace this gas oven with an electric one ? . Electric ovens require their own dedicated wire and fuse ? - or do they come with a plug i.e just plug in and go ...
ProDave Posted December 9, 2019 Posted December 9, 2019 Ovens don't actually use much, typically they are 2.3Kw and often do come with just a 13A plug. But the thorn in the side is fixed heating appliances over 2KW are supposed to be on a dedicated circuit. 1
Pocster Posted December 9, 2019 Author Posted December 9, 2019 36 minutes ago, ProDave said: Ovens don't actually use much, typically they are 2.3Kw and often do come with just a 13A plug. But the thorn in the side is fixed heating appliances over 2KW are supposed to be on a dedicated circuit. I guess an induction hob equally draws little current. Are most electricians qualified to cap the gas so a swap to electric can be made ?
SteamyTea Posted December 9, 2019 Posted December 9, 2019 2 hours ago, pocster said: Do gas ovens have fans ? Sounds like you are cooking a parrot, a live parrot.
ProDave Posted December 9, 2019 Posted December 9, 2019 43 minutes ago, pocster said: I guess an induction hob equally draws little current. Are most electricians qualified to cap the gas so a swap to electric can be made ? Induction hobs usually draw a LOT more than an oven. An electrician is not qualified to cap off a gas supply unless he is also gas safe registered. 1
Pocster Posted December 9, 2019 Author Posted December 9, 2019 7 minutes ago, ProDave said: Induction hobs usually draw a LOT more than an oven. An electrician is not qualified to cap off a gas supply unless he is also gas safe registered. This pack suggests it’s ok ???? https://www.myappliances.co.uk/prod/Oven-Hob-Packs/art50606-oven-and-hob-pack.htm?gclid=EAIaIQobChMI6YWNuJup5gIVybHtCh0cuwG7EAQYAiABEgJsXPD_BwE
ProDave Posted December 9, 2019 Posted December 9, 2019 13A is 3KW. Put all 4 rings on and that's 750W per ring available. I hope you are not in a hurry. 1
Pocster Posted December 9, 2019 Author Posted December 9, 2019 2 minutes ago, ProDave said: 13A is 3KW. Put all 4 rings on and that's 750W per ring available. I hope you are not in a hurry. Ok it’s crap . 32A for hob ; seperate supply
SteamyTea Posted December 10, 2019 Posted December 10, 2019 8 hours ago, ProDave said: 13A is 3KW. Put all 4 rings on and that's 750W per ring available. I hope you are not in a hurry. Don't they swap the power between 'rings' when more than two are on. And isn't it 10A for a continuous load on a socket?
dpmiller Posted December 10, 2019 Posted December 10, 2019 depends. There's good practice, and there's what happens. And how do you quantify continuous?
Temp Posted December 10, 2019 Posted December 10, 2019 Perhaps go for a dual fuel set up. Electric oven with a gas hob on top. https://www.google.com/search?q=60cm+dual+fuel+cooker&oq=60cm+dual&aqs=chrome.0.0j69i57j0l2.5777j0j8&client=tablet-android-pega&sourceid=chrome-mobile&ie=UTF-8#scso=_PvXvXYOdLqaU1fAP_emMmA474:0.5
Pocster Posted December 11, 2019 Author Posted December 11, 2019 15 hours ago, Temp said: Perhaps go for a dual fuel set up. Electric oven with a gas hob on top. https://www.google.com/search?q=60cm+dual+fuel+cooker&oq=60cm+dual&aqs=chrome.0.0j69i57j0l2.5777j0j8&client=tablet-android-pega&sourceid=chrome-mobile&ie=UTF-8#scso=_PvXvXYOdLqaU1fAP_emMmA474:0.5 Nah - don’t like tenants having gas . Gone for electric oven and induction hob - electrician will run a new feed for hob .
Liam Posted January 30, 2020 Posted January 30, 2020 To do this properly, contact the gas company and specify who you need to call for your work. Let 3 qualified specialists do it better. I saw a gas explosion indoors, believe me, you don't want it. Switching to electricity is a good step! Electric stoves and sockets are standard, but check with a consultant or electrician to find out which sockets will work. Every rule has an exception, so it's better to ask specialists than to overpay later. 1
