Red Posted November 12, 2019 Share Posted November 12, 2019 Hi probably been covered but here goes, looking to insulate attic truss pitched roof and Hybris insulation keeps being suggested to me but I have no experience of using this product ,my timbers are 175mm so a 125mm Hybris between timbers along with the 40/45mm Hcontrol Hybrid over the top,taped counter batten and plasterboard, in the past used the appropriate Kingspan etc with insulated plasterboard, fitting the Kingspan is a job I don't personally enjoy so potentially the Hybris is a less time consuming less messy alternative, so any thoughts appreciated Link to comment Share on other sites More sharing options...
Russell griffiths Posted November 12, 2019 Share Posted November 12, 2019 I’m sitting here waiting for the agro to start. C,mon who’s going to throw the first one. Link to comment Share on other sites More sharing options...
PeterW Posted November 12, 2019 Share Posted November 12, 2019 Hybris is an odd product as it’s not the same as the foil crap, it has a honeycomb back to it like a ‘’ normal” insulation. No experience of it in practice but I would expect it is a bit of a challenge to get the joints correct. Link to comment Share on other sites More sharing options...
NSS Posted November 12, 2019 Share Posted November 12, 2019 (edited) 6 hours ago, Red said: Hi probably been covered but here goes, looking to insulate attic truss pitched roof and Hybris insulation keeps being suggested to me but I have no experience of using this product ,my timbers are 175mm so a 125mm Hybris between timbers along with the 40/45mm Hcontrol Hybrid over the top,taped counter batten and plasterboard, in the past used the appropriate Kingspan etc with insulated plasterboard, fitting the Kingspan is a job I don't personally enjoy so potentially the Hybris is a less time consuming less messy alternative, so any thoughts appreciated We have 140mm Hybris between the rafters (105mm in the walls) with Hcontrol over, taped, counter-battened and plaster boarded. Works for us, but there are those on here who will tell you it's snake oil. Edited November 12, 2019 by NSS Link to comment Share on other sites More sharing options...
Red Posted November 13, 2019 Author Share Posted November 13, 2019 The limited information I can find regards the Actis product is not the present material ,I think a lot of negative opinion was associated with a earlier product but I have no experience of either , Link to comment Share on other sites More sharing options...
Red Posted November 16, 2019 Author Share Posted November 16, 2019 Had the rep for the Hybris product visit me ,obviously trying to sell the product promoting all the benefits etc also mentioned that its gained NHBC and LABC approval, price wise it's also cheaper per sqm than the make up that I am used to using , so Hybris or Kingspan etc Link to comment Share on other sites More sharing options...
EverHopefull Posted November 16, 2019 Share Posted November 16, 2019 I was shown this product at Scandia HQ when visiting their show home recently. They are offering it along side the standard insulation, no mention of cost difference but the show home was filled with it. Link to comment Share on other sites More sharing options...
Jeremy Harris Posted November 16, 2019 Share Posted November 16, 2019 The issue here is that initially this company was promoting a product that didn't work in the way claimed at all. Caused a stir and a lot of suspicion, as they had claimed that the multifoil element could provide far greater levels of insulation than it can in practice, and consequently there was a fair bit of mistrust (well-founded, given the chequered history of the introduction of multifoil products, with their ludicrous and easily disproven claims). They changed the product completely, so that now it works almost entirely as a conventional insulation material, the foil layers do very little, other than, possibly, reducing air movement a little bit. There's no long wavelength IR to be worth being bothered about inside the fabric of the structure, so the foil is now really only there to differentiate this product from competitors. It's performs at about the same level as most other fluffy-type blanket insulation materials, and they are quoting a sensible value for λ of 0.033 W/m, pretty typical of a fibre-type insulation (rock wool is around 0.032 W/m.K, wood fibre is around 0.037 W/m.K, PIR foam is around 0.022 W/m.K) . It's no better, or worse, than most other fluffy type insulation, but that's wholly down to the honeycomb fluffy stuff, not the foil layers. It does have the advantage all fluffy blanket type insulation has of being relatively easy to fit well between frames, and an additional advantage in that it is as clean and comfortable to use as wood fibre (so much nicer than rock wool). The downside is that it has a pretty short decrement delay when compared to wood fibre, or even rock wool. 1 Link to comment Share on other sites More sharing options...
Temp Posted November 16, 2019 Share Posted November 16, 2019 (edited) Best me to it. Edited November 16, 2019 by Temp Link to comment Share on other sites More sharing options...
Red Posted November 17, 2019 Author Share Posted November 17, 2019 Thanks for the opinions will stick to what I know, Link to comment Share on other sites More sharing options...
