Not strictly housing-related, but I'm trying to source some lightweight aluminium channel material. Ideally around 50x50mm. It's to form part of a solar panel support on a boat.
I can readily enough obtain chunky 3mm thick material, but I don't need anything like that sort of strength, and I don't really want the extra weight.
I know that much lighter extrusion and pressed channel is available for use in things like sliding doors, but despite extensive Googling I'm really struggling to find anything.
If anybody has any ideas about where I might obtain something like this, that would be much appreciated.
Could you use 50x25mm..?? 3mm is about the thinnest you’ll get at that size unless you got it folded. 3mm isn’t that heavy either - are you sure it’s going to be a problem ..?
Maybe ebay or gumtree - someone replacing sliding doors - could you recycle what they don't need? Guess depends on your need for either time saving or money saving - good luck
@Crofter
Not sure if you have sourced this yet, But I was in a place called MacSalvors (very well known don here for odds and sods), they have some channel that is what sounds like you are after.
Give them a call, and if you have no luck closer to home, I can get you some and post it up.
https://www.macsalvors.com/
Edited by SteamyTea
Hi @SteamyTea thanks for that, I will see what they say.
I'm not needing the channel any time soon really, bit of a long term project.
Thinking about a slight redesign as well which would reduce the amount I would need, so using heavier gauge material would be less of an issue.
