Stud wall insulation density
cwr
I've specified the following on my plans regarding stud walls, of which there only a few in our otherwise block build house plan:
• Where stud walls are provided between a bedroom and kitchen / utility / bathroom / en-suite or living room then provide a min 38x75mm timber studs at 400mm centres with minimum 25mm mineral wool quilt suspended in void.
Building control have come back asking me to 'specify density of mineral wool used for stud walls'.
Any advice on density to specify?
Thanks
Most of the site work I do is 25 mil
Which will stop the sound bouncing around Though we tend to use 65 mil for bathrooms
In your case I would put 100 mil in all Like me you have very few studs As long as what you put in is acoustic
  • 1 month later...
