Onoff Posted September 3, 2019 Posted September 3, 2019 Anyone know what the standard size for the o ring is? Measuring one I reckon 7mm internal diameter, 1.5mm section. Cheers
Temp Posted September 3, 2019 Posted September 3, 2019 I wasn't able to google that info but found whole tails with rings for £3:45 inc delivery from UK seller on eBay. Swap the rings over if not right length? https://www.ebay.co.uk/itm/10mm-x-1-2-BSP-Fitting-Basin-Monobloc-Mixer-Tap-Connector-Flexi-Hose-Pipe-Tails/162644180159?epid=2202974869&hash=item25de593cbf:g:CJwAAOSw~T9aawZt&redirect=mobile
Onoff Posted September 3, 2019 Author Posted September 3, 2019 It's just the o rings I'm after sourcing and 7x1.5 is what I've measured them at.
ProDave Posted September 3, 2019 Posted September 3, 2019 https://www.ebay.co.uk/itm/Nitrile-7mm-ID-x-1-5mm-C-S-O-Ring-Choose-Quantity-7x1-5-New-Metric/293135773763?hash=item444040f043:m:mZAHIXQV1FNd_PbsrtdbwwA 1
PeterW Posted September 3, 2019 Posted September 3, 2019 36 minutes ago, Onoff said: It's just the o rings I'm after sourcing and 7x1.5 is what I've measured them at. When do you need them..?? Got a whole box of different sizes I can send you. 1
Onoff Posted September 3, 2019 Author Posted September 3, 2019 14 minutes ago, PeterW said: When do you need them..?? Got a whole box of different sizes I can send you. Thanks. They're for work. It's for inside some posh £500 taps with built in pir. I took my own "big box in but the closest I had was 7×2. I then noticed the tap tail ones looked a fraction smaller on the section at about 1.5mm. I'll just tell them to source a load of 7x1.5mm. Was hoping there was a standard for the tails. Thanks again.
