Adam2 Posted August 12, 2019 Share Posted August 12, 2019 Hi, interested to know what ICF builders have done for attaching things like external lights/guttering/cctv/other random things to the outside of their houses. Going through to the concrete seems a little excessive. Our finish will mainly be render on a mesh on the EPS though I've been thinking maybe of using cement board but this will add quite a bit to materials & labour I expect so good to hear any inventive options you've used ? Link to comment Share on other sites More sharing options...
Russell griffiths Posted August 13, 2019 Share Posted August 13, 2019 Things like gutter will fit to facia board, cctv can go under the soffit, I have thought of fitting 250mm squares of compac foam cut flush into the surface to fit any other things in random positions. I think it’s a case of careful planning. Link to comment Share on other sites More sharing options...
scottishjohn Posted August 13, 2019 Share Posted August 13, 2019 (edited) you could set in studs before pouring the walls for attaching things outside of render? fit plenty and cut of flush what you don,t need? hardly a big deal holes in concrete with modern drills to fit a facia board to mount things any way you could fit it before render -and render up to edge ? Edited August 13, 2019 by scottishjohn Link to comment Share on other sites More sharing options...
magnethead Posted August 13, 2019 Share Posted August 13, 2019 (edited) Here's some nice fixings, when you want a drainpipe your kid could climb up, These are fixings from Fischer I have seen these used before, they are like LARGE plasterboard screw holders and these are the only houses with external insulation that I have personally seen the drainpipes detach from .... I would be going for concrete everytime, where there is something with any weight hanging off it. Edited August 13, 2019 by magnethead Link to comment Share on other sites More sharing options...
Conor Posted August 13, 2019 Share Posted August 13, 2019 If you plan properly, and align your webs, you can screw in to these as you would for internal fittings. So you'd make sure there is a web inline with your downpipes. You'd obviously just get one of the screws in per bracket, so use one of those EPS fittings for the other. Link to comment Share on other sites More sharing options...
Adam2 Posted August 13, 2019 Author Share Posted August 13, 2019 Thanks, yes for larger items (e.g. brisse soleil) was thinking to either set fixings pre-pour or cut out blocks of the EPS (and board over during pour) so we'd have concrete blocks to fix into. If we missed something we'd go with concrete fixings as suggested. After rendering I think it's tough to expect to find webbing with any accuracy unless you do something to make them identifiable but that's a pain for a whole house exterior. Will plan what we can and for small/light things (light exterior lights) those small screws with wide screw in plastic base look like a good option thanks. Link to comment Share on other sites More sharing options...
