vfrdave Posted July 12, 2019 Share Posted July 12, 2019 I have my thermal store in although not heated yet. First shower is in and I am a little concerned that the pressure/flow is low and it drops noticeably when you are looking for hot water (even though it isn't hot yet). Water is a balanced supply through a thermal store for hot and balanced off a multibloc pressure reducing and relief valve for the cold. Pressure at mains outside is 4-6 bar and flow somewhere around 40l/min. Can't keep the water in the bucket when running full bore at the start Haven't had a chance to chat with plumber yet as it is the holidays in NI but feels like the water system is strangled when it is within the house. Anyone got any pointers for me. Link to comment Share on other sites More sharing options...
Declan52 Posted July 12, 2019 Share Posted July 12, 2019 Is there a reducer on the shower head to limit the flow. Link to comment Share on other sites More sharing options...
vfrdave Posted July 12, 2019 Author Share Posted July 12, 2019 Just now, Declan52 said: Is there a reducer on the shower head to limit the flow. I don't believe so as they quote different flow rates based on pressure received up to 5 bar in their document. The cold and hot are balanced and reduced to 3 bar for the thermal store. The shower is the only outlet I have currently just seems to reduce in flow heavily when you turn the mixer round for hot water. Lowest temp setting isn't wonderful either. Link to comment Share on other sites More sharing options...
vfrdave Posted July 12, 2019 Author Share Posted July 12, 2019 Sounds like I'm in a not to dissimilar position to @Shell820810 just don't know if she got sorted. Our setups are very similar as well. https://forum.buildhub.org.uk/topic/1107-no-pressure-in-pressurised-system/page/2/?tab=comments#comment-14279 Link to comment Share on other sites More sharing options...
Declan52 Posted July 12, 2019 Share Posted July 12, 2019 Can you connect up something temp to another outlet in a kitchen/utility room and test it just to eliminate the different circuits. Link to comment Share on other sites More sharing options...
dpmiller Posted July 12, 2019 Share Posted July 12, 2019 watch the gauge on the PRV while someone turns on the shower... Link to comment Share on other sites More sharing options...
vfrdave Posted July 12, 2019 Author Share Posted July 12, 2019 29 minutes ago, Declan52 said: Can you connect up something temp to another outlet in a kitchen/utility room and test it just to eliminate the different circuits. I would need to rig something up temporary, although there is ballovalves in the kitchen I could open into a 5 gallon drum. The system probably has some air needs purged also. 18 minutes ago, dpmiller said: watch the gauge on the PRV while someone turns on the shower... There is no garage on the multibloc though I think one can be added to it easily. I'm probably concerned too soon before the system is purged etc though there is auto vent thingies. Link to comment Share on other sites More sharing options...
PeterW Posted July 12, 2019 Share Posted July 12, 2019 Its because it isn’t hot. Thermostatic valves need a temperature differential to operate - it’s locking down the flow because there is no hot water to open the wax cap. 1 Link to comment Share on other sites More sharing options...
