Temp Posted July 11, 2019 Posted July 11, 2019 We have a small cement rendered panel on our house that needs repainting. Can anyone recommend a make of paint for that?
Ferdinand Posted July 11, 2019 Posted July 11, 2019 (edited) I would probably go with normal masonry paint, in a colour and type that you know will not leave the market. I tend to use Sandtex if I have to paint masonry or render, and redo it every few years as required. F Edited July 11, 2019 by Ferdinand
Thedreamer Posted July 11, 2019 Posted July 11, 2019 @temp I envy you if your painting smooth render. I'm painting our roughcast and it's almost like applying an additional render layer in it self. We gone with a paint that's a bit more expensive and made on Skye. We have tried where possible during the build to help local businesses. http://www.isleofskyepaintcompany.co.uk/ 1
bassanclan Posted July 11, 2019 Posted July 11, 2019 I would recommend Johnsons self cleaning masonary paint. It's expensive, but a lot cheaper than the labour of repainting. I don't think much to Sandtex. It used to be good, but I think they have changed the mix over the past couple of years.
Simplysimon Posted July 12, 2019 Posted July 12, 2019 i could never understand sandtex, as an outdoor masonry paint i would want as smooth a paint finish as possible. having it smooth doesn't allow dirt to accumulate, sandtex on the other hand is a rough texture which dirt will adhere to. in the past we used weathershield masonry paint
Temp Posted July 12, 2019 Author Posted July 12, 2019 Thanks I'll have a look at the suggestions. The render already has a slightly rough texture so I think a smooth paint is probably the way to go and will stick well. Low maintenance is key for me as I need a scaffolding tower to get to it safely.
gravelld Posted July 18, 2019 Posted July 18, 2019 I've actually taken the plunge with this, will report back at some point.
