DavidFrancis Posted September 17, 2016 Posted September 17, 2016 As per the title. Is there a sealant that would seal this hole satisfactorily? Tried a few searches on Google and could find nothing useful. Thanks in advance for any advice.
PeterW Posted September 17, 2016 Posted September 17, 2016 Is it coming out a lot ..?? May be best with something like CT1 or Sika under a jubilee clip tightened over the spot.
Construction Channel Posted September 17, 2016 Posted September 17, 2016 good shout on the jubilee, possibly some denso tape if the ct1 doesnt work
Vijay Posted September 17, 2016 Posted September 17, 2016 (edited) Maybe try silicone tape? https://www.amazon.co.uk/Everbuild-2SWELDBK-Silweld-Silicone-Fusing/dp/B007554ZI6 Edited September 17, 2016 by Vijay
Onoff Posted September 17, 2016 Posted September 17, 2016 I've tried twice on mine with a 2 part, Araldite like epoxy glue.....FAIL. Not on an easy bit either. Right in between plastic reinforcing bits. Built in obsolescence I reckon.
DavidFrancis Posted September 18, 2016 Author Posted September 18, 2016 Thanks for the replies. Unfortunately the lance has reinforcing fins/flanges (or whatever they're called) like some Karchers parts do, which makes clips or tape difficult to use. I suppose I could cut out a wedge of something, try sealing that in and then put a clip around that. Any other ideas?
Nickfromwales Posted September 18, 2016 Posted September 18, 2016 A picture with an arrow pointing to the leaking part would be helpful
Onoff Posted September 18, 2016 Posted September 18, 2016 This is sounding like the lances on the same cheapo ones I have from B@Q circa £30 each and bought on a whim when they've had them as specials. Going to buy a Karcher now. I reckon this lance is the same as the one I've got that's split: http://m.ebay.co.uk/itm/PRESSURE-WASHER-LANCE-FIT-CHALLENGE-XTREME-DIRT-DEVIL-HIGH-QUALITY-SPRAYER-/322240278492?nav=SEARCH
PeterW Posted September 18, 2016 Posted September 18, 2016 (edited) Karcher used to have a website where they sold all the factory returns - basically they made a good unit from all the bits returned as it was cheaper to ship someone new stuff rather than a replacement hose etc on the off chance the customer has it wrong. Mate bought one of the dogs danglies ones for less than 30% of list price. I've got one that's 4 wheel job and other than the patio cleaner that's useless, it seems to be still going strong. Just checked and they still do https://www.karcheroutlet.co.uk/products/subcat.asp?mID=Pressure-Washers&sID=Sale Edited September 18, 2016 by PeterW Added URL
Vijay Posted September 18, 2016 Posted September 18, 2016 17 minutes ago, Onoff said: This is sounding like the lances on the same cheapo ones I have from B@Q circa £30 each and bought on a whim when they've had them as specials. Going to buy a Karcher now. I reckon this lance is the same as the one I've got that's split: http://m.ebay.co.uk/itm/PRESSURE-WASHER-LANCE-FIT-CHALLENGE-XTREME-DIRT-DEVIL-HIGH-QUALITY-SPRAYER-/322240278492?nav=SEARCH Have you looked at Nilfisk pressure washers instead of Karcher?
Onoff Posted September 18, 2016 Posted September 18, 2016 6 minutes ago, Vijay said: Have you looked at Nilfisk pressure washers instead of Karcher? I'm aware of the name. Figured go Karcher for future spares.
DavidFrancis Posted September 19, 2016 Author Posted September 19, 2016 (edited) Nick - I was using the outlaws' Aldi one, which I borrowed and returned on Saturday. But the section of lance that started to leak is similar to the section attached to the patio cleaner here: https://www.amazon.co.uk/dp/B009QX8AO0?psc=1 (you can roll the mouse over the image for a better view) Edited September 19, 2016 by DavidFrancis
Nickfromwales Posted September 19, 2016 Posted September 19, 2016 I'm still unsure as to where it's actually leaking from sorry. Is it where the sections join ?
