For my garage conversion / extension I'll be laying a GRP flat roof covering (on new OSB).
One of the products I'm looking at (from a supplier previously recommended to me) has a 20 year manufacturer's guarantee, and a third-party fire test certificate - but it doesn't have a BBA (or other third-party) certification. My approved warrant documents don't specify it has to be BBA, and I don't have a structural warranty so no requirements there.
The supplier has advised that the only thing Building Control will want to see is the fire rating document, and I shouldn't have any problems (practical or paperwork) using their system.
Does that sound right - am I safe enough to go with that product? Or would I be better using a BBA system (which appear to be more limited in choice, and more expensive)?
Thanks,
Andrew
I have a Build warranty on ours
They excluded our flat roof from it as it Came with 25 years guarantee and the same period for product
They wanted a insurance backed warranty That an insurance company asking for another company to insurer the liability
in my opinion it’s not important
If you where to sell at some stage
Yiy could buy an indemnity
Given that the cladding on Grenfell Tower had a BBA certification as being resistant to the spread of fire, then I'd have to say that it's probably not worth the paper it's written on for some products.
  • Like 2
  • Sad 1
Its a minefield!  We have flattish roof +250sqm  our covering has BBA cert and the 20 odd year guarantee.  We also have a Premier Guarantee 10 year warranty in case we want to sell...we are old may need a care home in less than 10 years LOL
There is no right answer to your question sorry, your choice.
Thanks all, helpful comments. It's only a fairly small area (30sqm) relative to the rest of the house and we do not expect to sell. It's a warm roof, and actually low pitched rather than flat (around 8 - 10 degrees) so no issues with fall.
2 minutes ago, Mr Punter said:
In your case @andyscotland if as long as building control are OK then it is fine.
Unfortunately building control have to date refused to engage with the project at all - don't want to hear from me until I'm ready for completion certificate and on a couple of things I've attempted to confirm their approval of ahead of time they won't say any more than it's for me to ensure that I can demonstrate at completion it complies with the regs....
I guess basically I just want reassurance that if I put a non-BBA-but-fire-certified product on there the building control inspector won't make me replace it at completion...
I don't know if it is different in Scotland but with building control we have the option of either a full plans submission, where sure you would submit plans including the roof covering specification or a building notice which is for smaller works where you know they will comply.
In your case I would do full plans and would expect an approval or a conditional approval, where they list stuff that is non-compliant or more detail required. Once you have the plan approval, as long as you do what is on the plans you are fine.
slight segway, and it may seem an obvious thing to ask, but can someone please give a succinct explanation of the difference between a 'warm' and a 'cold' roof. Just so I can align my understanding with what it is.
I did a full plans submission, but the (approved) spec just says the GRP system and substrate needs to meet fire rating AC or better.
I didn't mention a particular manufacturer or anything more specific, though there is a general line at the beginning that all works and materials to comply with relevant BS and EN standards.
So I could assume that if they wanted to require BBA that would have been flagged already - but just a little cautious as my council (who will be inspecting) are known for being stricter than the council they subcontracted my warrant application to.
A warm roof has the vapour control and insulation on top, hard up against the covering. So the rafters etc are "warm" as they're inside the heated space.
A cold roof has the insulation between/below rafters and requires ventilation below the roof covering to prevent condensation.
Warm roof = insulation above structure and no need to ventilate as all structure is warm
Cold roof = insulation within structure and underside of roof deck needs ventilation.
Building Control will probably look at U-value and fire performance of external roof finish - this later requriement is down to building height and proximity to local buildings, etc.
Note that Scot Regs strongly advise aginst use of cold flat roofs as do relevant British Standards
