Everything posted by Post and beam
within conservation area, MCS install or not
Post and beam replied to Post and beam's topic in Air Source Heat Pumps (ASHP)
Well that is sort of the whole thrust of my question. Should i just ignore the grant and get it done outside of MCS at the best standard and price i can arrange. -
I just read the England relevant version on the .gov site. It does not say you cannot install in a conservation area, its just more restrictive. But even that is not that restrictive. Needs to be MCS or equivalent, ? and not for cooling or closer to the road than the house. Otherwise go for it -
No, simply to illustrate that a small box annotated as ASHP is drawn on the south side of the ground floor part of the submitted drawings. No other significance. -
I have today received a 32 page SAP calc report from my TF builders. Having scanned through it once i am overwhelmed by the amount of detail. It appears to repeat the same blocks of tabulated data. Is there a document that explains what to look for. On a summary sheet that has some but not all of the same figures i see a Design airtightness figure of .3m2/hm2 @ 50Pa And a primary energy target of 37.82 Kwh/m2. Which does not sound very good. Also see a primary heating efficiency of 219%. Does this translate to a scop of 2.2 or am i hopelessly off the mark? Thanks in advance as always keith
Thanks for the replies guys. My concern is that once i engage them there is no going back. Therefore, if they say that i dont have permission i am then committed to putting in a planning application. This removes my other option of quietly getting a non MCS install doesn't it? Planning will insist on an MCS certificate. -
It turns out my planned house is just within a conservation area. An ASHP was drawn on the planning application on the south side of the house but somehow i dont think i can justify saying this is tacit approval of same. So i have the obvious 2 options. Request planning and go for an expensive MCS install. or Buy the parts and try to engage someone that will connect it all up for me. I am not a plumber and just about bright enough to understand that my limitations mean i should leave this to someone else. Discuss Oh and thanks as always
Heat Pumps: What They Really Mean For You - BBC1 8pm today
Post and beam replied to MAB's topic in Property TV Programmes
Sorry dude, i did not mean you specifically when i said 'you' . I just meant why throw out all of the old radiators in any given scenario where fitting larger radiators to suit a HP is deemed necessary. Apologies for the confusion. -
Why would you need to replace all of your radiators in the circumstance where they were regarded as too small for your new heat pump. Surely some of the larger ones would work perfectly well in rooms that previously had small radaitors. -
Its this that i am hoping the collective wisdom can steer me away from. Thanks for your recommends.
I am getting close to having to engage someone to install my UFH. There is a lot of discussion here about particular brands of manifolds/pumps flow valves etc. I (will) have 114 metres of ground floor in 2 zones only and am looking at 100-150mm spacing of pipes with a flow temp as low as makes good sense. What brand parts would i ideally specify and why please ?
Modulation % of Riello
Are these heliotherm units available in the u.k. They look interesting and not heard of them before. Edit: Found them -
Achieving as good a Scop figure as possible is obviously a good goal. But.... I am moving from a small 3 bed semi built in 1986 of approximately 93 sq/m. And building a highly insulated 200 sq/m house. I doubt that even if i dont get the kind of Scop that i aim for that the new house will cost as much as the old one to keep warm. Lots of discussion focuses on x design factor being a little off will mean your new house will cost more to heat. True when comparing variations of the new build but probably not true when comparing, in my case, where i am moving from. Have i missed the point?
Thanks dude -
Apologies, are we talking about the Riello or the Samsung now? -
Thats good to know. At least they publish theirs. I could not find the figure for Samsung of similar size. The 'end of line' samsungs also look to be very good prices. And, as i have been informed on here before now 'Get a Samsung you wont go wrong' -
I have been drawn to considering a Riello 6kw heat pump. Possibly 8kw. Looking at the documentation and remembering that modulation is important i see that they modulate to 40%. From what i have learnt here modulation to a 'low' value is considered important. So is 40% acceptable? What other factors might mitigate this. The units look to have a good Scop and price which was the reason for looking at them.
I am very grateful to be able to read all of the excellent content on this forum and have learned a lot. Still a lot more to learn of course. One of the things that confuses me is the cost comparison between the MCS route to ASHP installation versus the much cheaper cost of a traditional gas boiler. But, for a new build you also have to factor in the cost of a gas supply. In my case i am set on having a heat pump if i can get a reasonable quote. If a gas connection is anywhere close to what i have been quoted for an electrical supply @ > £6500 then the balance shifts, a lot. I dont recall this being part of the conversation for some reason.
Allowed placement, Under a kitchen window?
Thanks guys. That Vaillant diagram from @sharpener is exactly the one that i was given. It is a 7kw Vaillant that has been quoted for. As i am not keen on looking for a new location i think the best option is to find an R32 install -
Anyone living in an RV or 5th wheel?
Post and beam replied to Post and beam's topic in General Self Build & DIY Discussion
Possibly Really ? https://www.hireanrv.co.uk/rv-for-hire-uk-layouts -
£1000/month. Around here that would not even get a 2 bed flat. I need 2 bedrooms.
