Everything posted by Post and beam
MVHR Unit + Ducting Suppliers
Post and beam replied to Duncan62's topic in Mechanical Ventilation with Heat Recovery (MVHR)
One of our prospective plasterboard contractors said that it does not need plastering as the finish will be great as it is. Presumably after the edges have been feathered in. Hi said a light skim is all thats needed. Another prospect today has said that a full plaster coat is required. Anyone care to provide real world info please?
Planning on Brink 400, probably from Ventilation land. Have recently bought the 90mm ducting, will be progressing the ceiling holes prior to installing some ducting this weekend. -
Has anyone self installed Cedral?
Post and beam replied to Post and beam's topic in General Construction Issues
No but even if it doubled the cost of the planks themselves it would not come to £10k. -
No idea really. But, you can, and i have previously, costed the planks themselves. You dont get anywhere near this figure in materials alone. The Cedral website has a cost estimator that uses your square meterage as a basis for the estimate. That came out at £7500-9500. When i spoke to them to ask why it was rubbish they had no explanation or interest in providing one. Stupidly i had based my budget on it and put in £10k -
I have Nick, which is why i thought to myself 'how hard can it be?' I thought £22k was a little excessive for our 4 bed detached house. Have asked for a couple more quotes today as we are getting very close to needing this done, well being ready to be done. It can wait if the timing does not suit the prospective installers. -
I am not a DIY expert but i am also not a complete idiot( some may disagree) . My question is therefore, has anyone installed their own cladding and is it within the scope of the previously mentioned competence levels?
Cold roof, can some explain please.....
Post and beam replied to Post and beam's topic in Ventilation
I totally agree. No argument there. Which... is why i am trying to visualise a regime that gives me exactly that. My 1st floor ceiling ( airtight boundary) is as follows and from higher to lower 400mm rockwool 22mm caberboard decking 100mm rafters Intello airtight membrane Ceiling plasterboard Regardless of whether i go with my plan of boxed in light/ MVHR fittings within the 100mm rafter space being fed from above, below or horizontally i need to preserve the membrane as well as i can. i will provide a drawing tomorrow to better show the idea. -
That sounds like it makes keeping the integrity of the airtight membrane even more complicated. -
My understanding is that the roof membrane actually forms the watertight barrier from Rainfall. And that the tiles are there to protect the membrane. Am i wrong please? I have a little potential issue with the membrane and battening on the roof that the roofers are half way through. They have now broken up until the new year but i have a couple of small areas where rain has got in. Dormer valley for one of them and near to the gable ladder area for the other. I would rather my mind was put at rest and this be addressed before they crack on in the new year. Thanks in advance keith
Thanks for the responses yesterday guys, i feel more comfortable about this now. I intend to use the Pro Clima Intello Intelligent Airtightness Membrane at the ceiling ( warm side) Yes it is a pitched roof. I think there is a lot of work in making this Airtight boundary as good as it needs to be and still have access for the lights etc from the loft space cabling down through the membrane. Whilst also trying to make sure the plasterboard installers dont abuse my efforts. -
Yep that was my question from the other day. I have a lack of understanding of the role of the ceiling membrane in my cold roof .
Our build is a 'cold roof' according to the TF provider. The airtight boundary is at the first floor ceiling level between the plasterboard and the rafters ( not yet installed). With 400mm rockwool due to be placed on the loft decking. So the loft will be unheated, and presumably cold in the winter because the insulation should make this so. My confusion is therefore..... If the airtight membrane allows vapour to pass upwards into the loft will it not condense out any moisture contained within ? Have i totally misunderstood the role of the various membranes? Highly likely i think.
airtightness, first floor ceiling ?
Post and beam replied to Post and beam's topic in General Self Build & DIY Discussion
Having just watched this video, apologies , i tried to just insert a link. At minute 2:15 i now believe i was correct and i do in fact have a warm roof design. This is getting confusing . -
My effort to diagram what i have. I have seen descriptions of 'warm roof' that look closer to this than a cold roof design. Notice there is no insulation between the rafters here. Its all above, laid on the deck. -
The beams will be on show yes. Yes of course the airtight layer needs to continue above the beams. There will be a plasterboard ceiling . The question is.... It appears that the TF design calls for a boundary at the point between the plasteboard ceiling and the horizontals of the roof trusses. (Rather than the upper limits of the roof) so is the usual practice to box around the light fittings? -
Not sure if this is very clear, #1 shows the membrane above one of the beams. This is first floor ceiling. And #2 , the dark shadowy bit, Is the membrane above the studwork that makes up the first floor ceiling. So the perimeter of the first floor ceiling is a continuation of the airtight boundary from below. As stated previously, i could tape to, and continue this membrane across the whole first floor ceiling. No idea if this is the usual practice. But every light pendant would breach it and render useless. My TF frame company are very off hand now and just say ' this is for others'. Perhaps the usual thing is to box out the light pendant locations within the ceiling timbers, carry the membrane to these apertures leaving a smaller area to deal with after the lights are fitted. Any and all practical solutions or experience gratefully taken on board. keith -
At a loss to understand how i can create the upper airtightness boundary. -
No consistency at all, East herts did not want anything other than photos. In my submission for Bricks ,tiles and window colour i ended each sentence with ' or similar' . They did not comment or object which i feel gives me a degree of leeway should i need to change anything.
Hi Nick Described as a cold roof when i explained that the MVHR unit was going into the loft. 400mm of Ursa rockwool in the loft. -
The TF frame erectors have left airtightness membrane visible at the tops of the studwork and feature beams on the first floor. I conclude that the loft space is not regarded as part of the airtight envelope. I do not understand what i need to do next to maintain this envelope. I could of course tape membrane to the existing across the entire ceiling prior to the plasterboard being installed. This does not seem to be the correct approach though, i guess i have misunderstood something. #a: because the lighting installations would subsequently breach this everywhere and render it useless. What have i misunderstood please?
We have a large fireplace opening in the Sips panels of our house shell. There will be a large inglenook and working chimney. The TF company have washed their hands of providing any advice and simply say ' thats not within our scope, it is for your bricklayer' This is not within my skilset and i am at a loss to know how the hearth is to be integrated into the living room at 90 degrees to the Sips wall such that we maintain airtightness. No detail is provided within the construction drawings and my chosen brickie appears to be perplexed by the thing. I assumed this would be second nature to an experienced Brickie. Can anyone offer any real world experience of the subject please?
what size aperture for a 550 x 980 Velux ?
Post and beam replied to Post and beam's topic in Windows & Glazing
Thanks guys
