Kelvin
    48
Kelvin last won the day on November 7 2025
Kelvin had the most liked content!
4 Followers
Personal Information
  • Location
    Perthshire
Kelvin's Achievements
Advanced Member
Advanced Member (5/5)
1.8k
  1. Their EV charger does use the cloud so the advice is put it into manual mode (plug and charge) just in case the cloud service gets switched off and you then can’t access it to change it.
  2. My concern about SigEnergy. Ours has an insurance backed warranty whatever that’s worth in practice. It does still work without the cloud in a ‘safe’ mode. They are much bigger and better funded and are looking at an IPO. It is undeniably a slightly risky world PV/battery storage.
  3. I wondered about that too. The software side of it is a separate company apparently. Unclear how that survives if not enough people take up their subscription service. The good thing is it’s completely controllable locally with no phone home requirement. How you get spare parts remains to be seen. Bit of a nightmare for the installers as the responsibility rests with them for the first two years.
  4. GivEnergy has gone into administration unfortunately. Not clear what this means for customers.
  5. It’s likely fine without it however we used it and we only had one relatively small crack in the Cemfloor. Both the tilers that quoted for ours said they’d prefer to use it though were happy to quote without it. One of them said he’d just done his house and used it. There’s very little labour in it so it’s not as if it’s an unnecessary upsell.
  6. Not around us. If there’s a power cut the fibre goes off line.
  7. No issue with it on the ground. It just needs clear line of sight. You need to do something with the cable as it would be more easily damaged on the ground. Mine is buried in a duct that goes into the garage. You could also pole mount it. Starlink have changed their payment plans recently where they have cheaper plans for a slightly slower service which is fast enough for most people. I now have a reasonable 5G connection so thinking about trialing that to see how reliable it is. Openreach have also laid fibre all around us so that will be an option later this year albeit it’s susceptible to our frequent power cuts whereas Starlink isn’t (we have off grid capability) As much as I can’t stand Musk Starlink is fast (has become much faster over the last 4 years), reliable (we’ve had one outage), doesn’t seem to suffer from much contention, latency is good (low 20s), and has reduced in cost. We also got a free Starlink Mini Roam.
  8. No it ended up being slightly longer due to useless plasterer delaying me. I did run the ASHP in floor drying mode which I think took about 10 days. We had one small crack in the screed across the floor from a doorway into the kitchen.
  9. No just made sure the floor was as clean. 164m2. Yes across the longest room and at every door junction.
  10. Hence the importance of receiving a final window schedule that you approve. There were several errors in our window schedule. Why can’t they still be painted whichever colour you want? Negotiate a discount and for them to cover the cost of painting. Windows have a long lead time so you really want them installed. Ours are clear coat, which was an option, raw timber wasn’t an option as it impacted the warranty.
  11. All of that was done by the vendor as a part of our purchase of the plot. All of the subsequent plant equipment we installed was zero rated.
  12. I wouldn’t. I gave some leftover sheets to a friend who stored them in a garage with no door. I told him not to but he reckoned it would be fine as it was just a short time. All ruined.
  13. Two of the private water companies I dealt said they don’t use water diviners as they don’t need to but offered contact details for anyone that still wanted to use them. We had a go. It worked for my other half, and didn’t for me (we both knew where the pipes are) and it didn’t for the two other people that tried (and we didn’t tell them where the pipes were)
  14. This although we have two UV sterilisers, the treatment plant compressor does switch off and on, borehole pump although that probably only runs once a day, control panel for that, our water is pumped into the house. Other half wfh so there’s three screens, and a laptop. I also have a bunch of networking stuff and Starlink consumes a bit. We’re np about 450W background load. It was higher but have put everything on standby when idling or off overnight.
