eekoh
Everything posted by eekoh
Probably. Either strategy needs effective government regulation to keep the focus on quality of service & infrastructure rather than the vested interests of shareholders or union politics. Also I think if employees feel like they’re being treated fairly and not exploited or worked to death to fund ‘fatcat’ bosses they'd be less likely to form militant unions.
I think we'll struggle to develop really good systems designed to improve service for consumers or fully address 'green' objectives without either nationalised power generation or incredibly strict regulation, which the Conservative government seems reluctant to do. I'm not wholly against privatisation (and we're kind of stuck with it for the foreseeable future anyway) but in a free market its inevitable that private companies driven by profit will only do the minimum required to meet their service level agreements or political/legal obligations.
UFH for existing joist floors and manifolds for radiators
eekoh replied to Raks's topic in Underfloor Heating
@Raks Noticed this topic is a few months old so I was wondering how you’re getting on with your UFH and how it has performed? (I’m considering a similar retrofit install to an older property) -
At the price we’d be buying for there would be good scope to gain on resale value later. UFH is probably the biggest cost that isn’t necessarily essential (we could reinstate the existing radiators after plastering) and the cost will be one consideration on whether we do it. What I’m looking into now with materials & specifications is to inform that decision. The house is fairly typical construction for this area, I’ve rented 4 different homes with similar construction since moving here and several friends either have done or are in the middle of renovations so I am reasonably familiar with the issues of living in and working on stone houses. The house isn’t a complete wreck and has full mains services. It would be basically habitable with a good scrub down and a skip for the old carpets, so we could do a slow & steady program of refurb room by room after we move in. But while it’s empty initially and we have cash available it gives us an opportunity to consider some bigger things (like upgrading the heating) which could make it a better home but would be more difficult to do later on.
@scottishjohn demolition is not an option, we’d want a totally different sort of plot for a new build. From what I can see it’s plastered directly onto the stone, no sign of lathes on the bits that have broken away. Structurally seems in generally good condition, room sizes are mostly fairly big apart from box room on middle floor. From the decor it appears to have had a lot on money spent probably in the 80s but nothing much since. External (lime?) render is intact, internal plaster deteriorating fairly rapidly since it’s been empty. @Triassic yep, wool is quite bulky and also fairly expensive. I want to find out more about the hemp fibre products, they look good so far. possibly still expensive tho. @Temp it will have been empty for approx 1yr so we wont qualify under that scheme. I think we’d probably do at least some of the basic install ourselves and then contractors for the plumbing & electrics commissioned and screed.
@Ferdinand I'm not in any way set on sheeps wool, that was just one of the most frequent things that seems to come up on searches for breathable insulation. Of the products I've seen so far I'm actually leaning more towards the hemp fibre stuff as there is a local firm that works with it and from what I've read so far its very good on both thermal and acoustic insulation. @AliG Its got 18" thick stone walls so seems unlikely to me that there would be any rapid variations from external temperatures and UFH is used very effectively in stone barn conversions so why wouldn't it be suitable for a stone house? The constant heat output is better for keeping damp at bay than the alternating high heat / low heat, on/off approach of radiators, though I do take your point about needing to ensure a high enough heat output to warm the place adequately. I'm also aware that a suspended timber floor is probably less efficient than a solid floor as we wouldn't be able to use the same depth of screed, though the info I've found so far on Hempcrete screed suggests that you can get good performance from shallower depth than you'd need for concrete. Insulation is another aspect that I'm looking into, the whole solution will need to be a balance between heat input and insulation to reduce heat loss. I've got a bit more investigating to do working out where that balance would be with this place. There is existing external render which I think is Edwardian (identical appearance to another local building with known materials), which would be lime based though clearly will need checking as non-breathable render would create damp problems. We'd also be using lime or hemp-lime plaster for the interior so that would contribute a bit too.
So it looks like I may be going for a renovation rather than conversion / new build - there's an old house come up locally that my partner and I can afford and if we're successful at auction in Feb we'll need to get straight on with the work to minimise the time we need to keep our rented house so I'm attempting to spec & cost some of the work beforehand. (Also it'll be useful for any future project if we don't manage to get this place.) Its a stone cottage over 3 floors and as it needs a full refurb it gives us the opportunity for a 'blank slate' approach to the heating system. We're thinking of wet system UFH throughout - ground floor is partly solid and partly suspended timber (over a small cellar), upper levels are obviously suspended timber floor. Also we'd retain existing open fire (or replace with log burner) for extra 'instant' heat in downstairs living room. Solid stone walls so everything needs to be breathable to avoid damp problems and this is the main point where I'm looking for some advice. Lime (or possibly Hempcrete) seems the obvious choice for screed. Breathable insulation materials - so far options seem to be sheep wool or plant-based fibre board (wood / hemp) Does anyone have any recommendations or comments either pros or cons for any of these materials? Wool seems to be only soft rolls rather than boards - can you fix UFH pipes to these? Could you put lime/hemp screed directly onto wool? Do I need a solid fibre board for the suspended timber floors to maintain the weight-bearing load? (Not sure exactly how different a screed would be compared to floor boards in this respect) Thanks for any advice / comments.
agricultural land to residential (LPA local plan)
eekoh replied to eekoh's topic in Planning Permission
Most of what I've found from my research suggests that allotments do count as agricultural land use, and would not require permission for change of use. Same with orchard, it isn't a leisure/amenity land use, its the growing of foodstuffs and therefore agricultural. Small areas of general woodland can also be planted on agricultural land, though there is a cap on the size of area beyond which it becomes forestry and requires change of use. In fact the first thing that comes up with a google search of 'can I plant trees on agricultural land' is a Farmers Weekly article from Aug 2018 extolling the benefits of doing just that. You can't use an allotment as an extension of a garden so lawns or ornamental flower beds that would count as leisure use are out, but that's not what I'd want to do anyway. There are circumstances where growing flowers could be agricultural - e.g. for natural dyes, essential oils, cut flowers for sale. From other forums, where people have run into problems is where the plot has been adjacent to an existing garden and its been a bit less clear that it isn't an unlawful expansion of the garden or in some cases they've just thought that they own it and can do what they like without paying heed to the land use classification. Nature reserve is something different, and that was perhaps a misleading term to use in my original question. There are plenty of wildlife friendly things that can be accommodated within agricultural use without any official classification as a 'reserve'. Anyway, whatever I might use the land for in the shorter term, there remains the question of whether it would be feasible to get a portion of it included within the local plan at a later date and thus converted to residential rather than trying to prove a viable business to get a tiny dwelling consented under agricultural permissions. I have no desire to build (or live in!) a housing estate and they might not be interested in something as small scale as one or two dwellings, but it does seem plausible that such an approach could work within the current planning policy framework. Something to investigate further at least. If I could afford to buy a small farm it would be so much simpler! -
Yeah, I need to read up a bit on exactly what is permitted on agricultural land but I think growing fruit & veg should be allowed as they are foodstuff rather than ornamental and also beehives for honey. And lots of farms have native species hedgerows, set aside areas, species rich meadows etc - in fact there are environmental stewardship schemes to encourage farms to include more of this sort of thing so that should all be feasible too. You don't need to farm in a big commercial way for it to count as agricultural use, the bit where you'd need to prove its a viable business that needs you to live on site is if you're aiming to get consent for a dwelling on that basis alone. But what I'm considering is slightly different - at the Local Plan review the council would typically be actively seeking additional residential land and if the whole parcel was put forward by the likes of Barratts, Bellways, Wimpy etc they'd probably couldn't say yes fast enough! -
Yep, I'm aware of uplift etc. Its still far more feasible financially than buying a residential plot of the size that I want. I'd actually be perfectly happy to maintain most of my plot as agricultural. Unfortunately, there is very little provision in current English planning policy to create a new small-holding style development. -
So there's some farmland come up for sale at the edge of the town where I live. I'd very much like to build in or close to this town, but plots are hard to come by because its not very big and its surrounded by farmland. I could afford to buy a couple of acres (if the vendor is willing to split the land parcel), though as its agricultural clearly I wouldn't get permission to build a house on it in the shorter term. But what I was wondering is whether there is an opportunity to play the long game here the same way that a commercial developer would. Its adjacent to the settlement boundary and access is at the end of an existing residential lane so in theory, when the LPAs local plan is up for review in a couple of years time I could propose it for allocation as residential and they would have a perfectly logical and policy-friendly way of altering the official land use to permit a dwelling. Until then I could use it basically as an allotment, orchard and nature reserve (part of our longer term plan anyway if we can get a plot big enough) because that would count as agricultural land use and I could also probably get consent to build a barn. Anybody have any experience of this approach? Does it sound like a completely stupid idea?!
Wow, that really is a horror story! I take your point about being certain of your exit and I do feel for those folks, but seems they were already in a financial pickle before they went down this route (poor credit history and facing imminent repossession of a property) so turned to it in desperation rather than making a well-considered investment decision. Their lender sounds rather like a loan shark too rather than a reputable investment firm! For me its a very different situation, a loan would be a tool to facilitate getting a project started and only if it stacks up within the overall project budget and schedule - there is no way on earth I'd ever let anything financial get that out of control. I wouldn't be committing to that level of borrowing, I never 'just sign' without understanding the repayment terms and there would most definitely be a planned exit, either repaying it in full with a self-build mortgage or just selling the land - which would be a disappointing outcome, but infinitely better than spiralling debt.
@lizzie The finance will totally depend on the type of project. For some types the deposit will be sufficient to get a self build mortgage, but there's a particular one that I've found where the planning consent has lapsed so isn't immediately mortgageable. For this one it would be the bridging finance that makes it feasible because without it I wouldn't have sufficient capital to buy the plot, even though once I've renewed the consent the figures appear to stack up fine for a mortgage.
@Ferdinand Yeah I've seen the interest rates are higher than other types of loans, but as I'd only be looking for 50-60k even if I keep it for the full year the total cost is only about £5k, which isn't huge in the grand scheme of things. From my internet research so far lot of the bridging finance companies don't even do loans that small, though their max figure is millions! @lizzie If I had that much equity available I wouldn't be looking for bridging finance! (I live in a rented place with my partner now and I'll get about £50k cash some time in the next month from sale of my old house, which is the deposit for this project.)
is it difficult to borrow if you have a deposit
eekoh replied to Amateur bob's topic in Self Build Mortgages
While lending criteria may change over time, you're absolutely right that your project isn't going to get anywhere if you can't afford to build the design that you've got permission for. If you know that you'll need a mortgage to finance the build then it definitely seems sensible to work out the approx figure you might be able to borrow and get a rough understanding of the typical lending criteria. This is one of the things I've been doing over the last few months because the mortgage figure affects the total project budget available, which in turn affects how much I can spend on buying the plot. -
I'm looking into bridging loans as a potential means of part funding purchase of a plot - this would make a big difference to the type and size of plot I can buy, opening up potential opportunities for land where planning consent has lapsed or hasn't yet been sought. (I know there are other issues with that type of project such as risk of not getting consent, overage clauses etc but that's a separate thing and its the bridging aspect I need to understand first.) What I'm not clear on at this stage is whether the bridging loan is secured against the land purchased (as a mortgage would be), or does it need to be held against other assets such as another property, or can it be a combination of both?
An architect friend of mine’s build is one of 12 finalists shortlisted for the RIBA awards 2019 He put it forward himself because as a recently self-employed architect it’s a great endorsement of his work but having made the shortlist he’s expected to attend the awards dinner, which is pretty expensive. Not even the winner gets a free pass to that. Awards schemes may be nice, but not always free to take part.
- 25 replies
- awards
- brick awards
The sometimes laughable penalties for destroying bat roosts is another sore point for consultants and conservationists alike - I've had clients tell me to my face that they'd knock a building down and take the fine rather than pay for the necessary survey work and licence to do it legally. Cases like this where even a successful prosecution for someone knowing committing a crime results in a penalty that is such an insignificant amount in their overall project budget is little deterrent to that sort of developer. There are however several cases from the last few years where the penalty has been levied under the 'proceeds of crime' legislation, which allows the courts to seize a substantial percentage of the developer's profits - a far better deterrent than a fixed penalty.
Mortgage to buy plot but want to amend the consented design
eekoh replied to eekoh's topic in Self Build Mortgages
It’s not so much the structure of the house itself on this one (a conversion is always going to be more limited than a new build because of working with an existing structure) although I’d probably want to alter the plans slightly to accommodate some eco technology features more easily. But even if I miss out on this plot, because I’m not a cash buyer I’ll have the exact same situation whatever plot I end up with because it will need to already have planning consent before I could get a mortgage to buy it. I can’t be the first person to think of this surely? -
The plot I'm interested in already has full planning consent which was granted under PD for reuse of an agricultural barn. Unfortunately I don't have sufficient ££ to buy the land outright so I would need a mortgage offer based on the existing planning consent in order to get a sale agreed with the vendor before it goes to auction (which they are open to). I don't have a specific lender yet, but from my research there seem to be plenty who advertise they will lend against both the land and the build and I have a decent deposit so provided I can get land at the right price the numbers do all stack up. The main issue at the moment is that this plot has come up about 6 months too early and I've still got a fair bit of work to get all my ducks in a row! But its a good one so seems worth trying to bring things together now to make an offer. -
Sadly I hear this quite a lot - unfortunately government cutbacks mean many councils no longer employ a County Ecologist to advise on planning matters so that LPAs often don't have access to the in-house expertise on ecology issues that they would have say 10 years ago. Its incredibly frustrating for ecologists too when LPAs don't give consistent advice and completely understandable that people resent having to undertake work that they think someone else has escaped. It undermines trust in my profession and the lack of consistency encourages architects and planners to advise their clients to 'submit and see what comes back' rather than planning for things from the outset, which then leads to situations where applications are delayed because the survey season has been missed or bats are found when contractors start on the roof and everything grinds to a halt.
Yes, its pretty easy to tell bat from rodent droppings when you know what you're looking for, although not necessarily which bat species it is. Bat droppings crumble to a dry powder when squashed whereas rodent droppings will be hard pellets. We can also send a sample of the droppings away to a lab for DNA analysis to confirm bat species (usually about £50-60 for the test), but there would probably still need to be some emergence surveys to get the more detailed info needed about where bats entry/exit points are, how many bats are using the roost and whether they are raising young on site (maternity roost) because that affects how the mitigation would be designed.
Hmmm, having read some of the threads and comments referring to vampire bats, expensive flying vermin and folks bemoaning the 'unnecessary' LPA request for & cost of ecological work I'm hoping that I don't get too frosty a reception, what with me being a bat ecologist. ?
As a bat ecologist, I can assure that the council are entirely correct in their request for you to provide them with an ecological assessment of your proposals - they have a legal responsibility to consider impacts on protected species such as bats. The fact that not all councils do request this information is down to lack of resources & knowledge in the planning departments resulting from however many years of austerity and cutbacks, not because its optional or somehow at their own discretion - in fact if you do get planning consent without this information there are a number of precedents for planning permission being challenged and even overturned due to the LPA failing to assess it adequately on all of the aspects they are legally required to consider. If you have a plot next to a canal (even if its in the centre of a city) and your architect told you that bat surveys wouldn't be needed then he/she hasn't provided accurate advice and really should know better. It's also entirely possible to have had bats in a building for years without you ever realising. If I had a tenner for every time I've found bats roosting where a client has told me 'there's no bats in our barn/house, we've lived here for years and never seen a single one' I'd be as rich as people seem to think us ecologists are! It is normal that a daytime inspection alone isn't adequate to confirm whether or not bats are present. There are several different bat species that use buildings in different ways and not all of them leave evidence in places where it would be obvious to see so if the building has suitable features then emergence surveys to watch for bats actually coming/going is what it takes to comply with the current survey standards that the LPA can rely on when assessing your application. Trust me on this, ecologists are not doing things just to make your life difficult or line their own pockets by screwing up your development. Our role is to provide specialist advice on a specific aspect of your project that your architect/planner/builder/surveyor simply isn't qualified to do, and to make sure that you stay on the right side of the protected species legislation and don't expose yourself or your contractors to prosecution for wildlife crimes.
If you’re not already sorted you could try James Boon Architects, based in Derbyshire Dales. His own self build (Stackyard) is shortlisted for the RIBA East Midlands 2019 awards.
