Marvin
    3
Marvin last won the day on August 25 2022
Marvin had the most liked content!
Personal Information
  • About Me
    Broad experience in construction and still learning. Refurbished own bungalow in 2018 still tinkering.
  • Location
    Isle of Wight
6854 profile views
Marvin's Achievements
Advanced Member
Advanced Member (5/5)
551
  1. Hi @JohnMo I will come back to this if you don't mind. I need to change my inverter to one that will allow my system to charge batteries, supply to the mains, and go off grid. Is there such a thing?
  2. I want to add some more PV panels to my system. The ones I have all face south with no shade The panels I want to add will face east and west. What sort of panels can if fit to the two separate rings I already have without losing power from the existing ones?
  3. Could it be that Australia has more sun and therefore each system produces more energy per year than say, a UK one, and therefore the outlay produces more income?
  4. We have radiators, and when we tried using the ASHP for cooling, if we ran it at 18oC condensation dripped off the radiators so we don't use our ASHP for that.
  5. Ditto. In May, we paid more for the standing charge and VAT than the electricity we used.
  6. I have used 20+ time delay on off / relay switches from GEYA and found them all ok. Sometimes the instructions have been a little hard to understand but maybe that's just me.
  7. That's non setting electrical putty https://www.google.com/aclk?sa=L&ai=DChsSEwjV_aGfyr6TAxXzjFAGHbGsIjYYACICCAEQAxoCZGc&co=1&ase=2&gclid=CjwKCAjwspPOBhB9EiwATFbi5BkanPos5dLixv0wSp1V_3WAHOacGQ1jnwucOEUEE5d2-PmOgYSP0RoCFW8QAvD_BwE&cce=2&category=acrcp_v1_32&sig=AOD64_1l9R1G1FCGLV_DOlYmv6FsI1sd3g&ctype=5&q=&nis=4&ved=2ahUKEwja35Wfyr6TAxWeQUEAHfLbLX0Q9aACKAB6BAgFEB4&adurl=
  8. People are starting to catch on (excuse the pun) https://www.fireprotectiononline.co.uk/fire-extinguishers/lith-ex-fire-extinguishers/
  9. We have a small MVHR. I swap the filters every 6 months - have 2 sets so wash /clean the swapped set. I had a problem and it came down the the bearings on one of the fans (after 8 years). Replaced both sets on both fans. And whilst there cleaned the inside of the MVHR. Seems alright now.
  10. With us: Heating: ASHP to water to radiators Inverter outside, Batteries outside, ASHP on roof MVHR unit in loft - fully insulated In utility room: 205litre cylinder - 300mm insulated, Buffer tank - 300mm insulated, all controls and valves- insulated Washing machine, Condensing dryer, Clothes hangers Current temperature in utility room 23.1C The room gets quite warm when washing and drying which is useful otherwise no problem. Never had a moisture problem anywhere in home. Our home is quite small compared to a lot on here -104 square metre floor area. I know of one friend who is doing that sort of thing on a big scale - circulating the heat in the house via another duct system! Our windows are east and west facing and the one thing I wish I had done was put in a system to take the heat from the east end in the mornings and send it to the west, and the reverse in the afternoons during the Autumn and Spring.
  11. Absolutely, and purchasing of gas when supplies are cheaper...
  12. Yup. And if proven to be successful will be a game changer! Thats why I put as much PV in as possible..
  13. Er, I was thinking people should wear it.😂 But on a serious note our home produces more energy than it uses in a year, just not when we need it. We need good energy storage.
  14. In the UK 45-50% of energy is used for heating. What we need is more sheep. We can then produce more wool.
