markocosic
    1
markocosic last won the day on August 3 2024
markocosic had the most liked content!
2 Followers
Personal Information
  • Location
    Lithuania
markocosic's Achievements
Advanced Member
Advanced Member (5/5)
291
  1. My wife silly money for doing this. (the adding patina creatively and then varnishing it part) You supply the door with the metal attached at your own cost. That's the easy part. 😉 Or you buy the sheet then glue it to your own door. (and no she can't/won't post massive sheets or warrant the lacquer and it remaining as-patinated for outdoor use) https://www.etsy.com/shop/BalticMonkey - Buy timber door - Go to a place that does copper/brass in 0.5 to 1.0 mm thickness (0.6 and 0.7 mm pretty common) for about £60-80/m2 - the local metal roofing shop is a good bet - Glue it to a slightly oversize timber door - Trim it to finish size using a tracksaw with nice sharp blade - Add patina with "secret sauce" (various acids, alkalis, etc - if doing daft things with heat/oxygen* then you need to patina it before you glue it to the door) - Laquer it to all heck OR leave it as is and accept that it will change Probably buy yourself a few sheets before you start for practicing on. Getting your patina right is the bit that needs practice. Nothing that's out of the reach of DIY but you'll be corroding then washing / sanding and trying again with brass for a while before you get it right.
  2. Just fix it. Shimming little double glazed units is easy. Buy yourself the plastic wedge/lever so you don't bugger the glass and get on with it as per below: I've just done my 2100 x 900 mm full glass / triple glazed units - heavy swines - much the same way. Used birch ply spacers (on top of the channel spacer) rather than plastic as the plastic has a tendency to deform over time where the birch does not. That, and I had the birch ply and a chopsaw to cut it to size, but no plastic. Timber cut end grain also works.
  3. We did not @markharro - 50 x 50 mm battens on 600 centres - 50 mm mineral wool between battens - 120? mm tongue and groove over the top Because: - She who must be obeyed liked the look - It'll get handprints on it on the mezzanine that would be a pain with wood wool - Plasterboard painted would have showed every mark / cracked at every opportunity Acoustically the T&G over mineral wool is fine. Not as hard a reflection as plasterboard. The gaps and air movement to the mineral wool probably aid acoustics.
  4. Dezincification?
  5. Evacuation back into outdoor unit and nitrogen purge and vacuum out and refilling indoor unit required. A lot of faff to avoid an aerosol tin of propane leaking outdoors. And no filter drier to catch any ick if you do introduce this by brazing. I'd ignore it if you're trunking it anyway. Perhaps braze the next one end to end and clad over it though! Or say fuggit and flare indoors even though it's R290. (probably be legal by then - the EU is busy upping the allowance for how much R190 can be in splits etc at the moment)
  6. The conveyancing involves sweet fanny adams if it's a registered freehold title. Worth not relying on the bank's own conveyancers; as they have, without fail, been woefully inept on every mortgage transaction I've ever been involved in. Do it yourself. If they won't deal with you then find somebody clueless but cheap who will do Simon says conveyancing. (doing it yourself and having them sign it afterwards) This may well be the bank's inept conveyancers - provided that they don't have room to screw up your plans by doing things wrong.
  7. Ah, propane! In which case braze the lot bar the joint at the outdoor unit 🙂
  8. IMO don't install that way rather than trying to make midpipe joints serviceable: - Route pipework for indoor unit such that the flares are indoors behind the unit. (there's space for this designed in) - Buy longer linesets when installing or have the installer braze them. - Use a leak detector when installing (heated diode units are about £50-75 and sensitive down to 3grams/year)
  9. Neatest? Hide them behind the cladding. Easiest after the fact? Black air conditioning trunking. Comes in to halves. Clips together. Ends and bends etc all available.
  10. I set fire to a dark towel over the back of a chair placed over a metre from the fire when using it for the first time. Sub 200C double walled convection stove it might be. Doesn't prevent numpty from lighting it up, arranging their wedding shoes and towel a comfortable distance from it at startup temperatures, then coming back 15 minutes later to a secondary fire from the radiant heat!
  11. Agree that it's upfront easy. It's just efficiency ugly is all.
  12. You build traditional balkan houses. Ground floor? Where you overnight then pigs/cows/sheep in winter. First floor? Where you overnight then humans for most of the winter. The solution need not be sophisticated. You have more choices in the UK though. There isn't a real winter. There are plenty of economic opportunities should you choose to follow these rather than following passions.
  13. Not buying it as the 'ultimate' option. Spark ignition CHP running on methane from the cow shed / naerobic digestion plant plus syngas from wood gasification. LPG as your easily stored "pilot light" fuel for starting it up. PV for offsetting demand for fuel entirely. Screw *buying* in diesel. Cheating; more reliant on others outside your borders; easier to pinch in bulk than slurry/wood/LPG?
  14. But oh so easy and inefficient! 😉
  15. Convert a Prius to LPG. Locate engine etc in the garage for waste heat capture from block. Plate heater exchanger into an LTHW buffer vessel for high grade heat to house/hot water. Electricity to keep the lights on/fridge on/internets happy. And run a heat pump if you need more heat than electricity. Offset your LPG using bucket loads of PV with an island capable inverter and battery combo. Gasify wood and blend that with the vapourised LPG for extra style points. Interlink the Prius battery/PV inverter battery for extra style points. How can we make this more complicated?
