SimonD
Everything posted by SimonD
Thank you for the heads up! I just checked back a realised I'd got a couple of things confused. The MIs had been specced donkeys ago for a system that was also on the main roof and included the south face of the garage to account for the predicted shadowing over the year! This plan never got anywhere because the solar designer couldn't find a roofing contractor that would touch our roof and standing seam. So, yes, scrub the suggestion of MIs into the inverter.
There are some installations where installer will put a tee and ball valve off the flow & return outside. They put them before the heat pump isolation valves so you can isolate the heat pump and flush the system through - there are pros and cons to this approach. Just then make sure all the pipework is properly insulated. If you do a fill and flush setup, if you're using mains rather than a pump flushing machine, just make sure you've got easy access to mains water outlet.
Yes, I dread to think about 1) what it'll take to clean a standing seam roof that's been on for 6 years prior to installation and, 2) what it would take to clean to roof when replacing the panels - at end of life or following premature failure. It just took me 20 minutes to clean the old adhesive off a Festool saw guide rail to put a new splinter guard strip on!
Good point. The hybrid inverter I'm looking at has dual string capability, so I can run the south face on one string and then use MIs for a second string without compromising efficiency. These MIs cost a pretty penny don't they so if I can reduce this it would be good!
We're on Octopus intelligent go, so just going through a calculation to understand our usage patterns. We're currently paying average of about 17p/kWh so there's room for improvement. I will look into this.
Would never dream of it - I actually installed the whole roof myself so there is no way I'd let someone touch it in a way that would compromise its integrity. Yes, that's the idea and also because curved standing seam roofs are so common. But following my research I have a feeling the industry has a bit of a problem with the standing seam clamps. Many of them essentially have a lip and use a grub screw, or some other type of vice clamp. The grub screw versions I wouldn't used on mine because this would almost certainly damage the coating and also potentially damage the galvanised surface. So either which way there are risks. Apparently it has been designed for retrofit - but I have some questions about how this would successfully meet the real world of a standing seam! Most other similar products are factory bonded. Apparently fine - it's suggested that it would be fine with my Greencoat PLX roof - but would need to confirm this with the manufacturer as they even had some very clear instructions on the type of sealant that's acceptable in the double seam - which is required in some installation instances where there's a very shallow pitch such as mine.
I've got max 7m x 2.2m minus a velux window which I can easily remove or just panel over on a south facing garage roof and could double that if I went with north facing panels. But this gets shaded by the house in the winter - so could use mini inverters. Then I've potentially got a 3.5 x 2.5, garden room roof but that's right at the other end of the garden compared to the garage. Just accepting the limitations of the garage, plus adding some batteries could be the first step, accepting the limitations.
This is definitely my concern particularly given the length of our panels and the expansion I had to account for when I installed the roof - I just wonder how these pv units can cope with this over the long term.
I'm rapidly beginning to wonder if battery first step is the way to go and just use the TOU we've got and rarely use our full allocation.
Just got an email from my standing seam roof supplier but the followings stick on solar panels. I have no idea about price but given the shape of my roof, this could be a solution. At about 17.5% efficiency are these any good? https://bipvco.com/flextron/
That is shit. I have this sense that I'm always being tested, a bit like a A/B test. I was doing some stuff and started a new chat session and it was giving me the commands to run in terminal and paste back the outputs - now in a way because it's all on a local dev server and we were doing a load of reconfiguration, I can understand this. It then started giving me the code snippets to copy & paste into the code. On one liners or something that's fine, it's quicker and easier than producing a prompt to then go into Claude Code etc. But it's all a bit random - every day the flavour of the sessions changes and it can all be a bit random.
Hmm, IMHO I'd be a bit cautious about that blade. I know Rutlands have built some kind of reputation, but I bought something from them that was total and utter over-priced rubbish. I was reluctant to touch them again until I ordered some tools from Bang Good having watched the YouTube channel 'China tools' - and yes there are some quality bits of kit that can be had - but what was very interesting is that one measuring tool I received came with Rutland written all over the tool and packaging even though it was from a totally different vendor and about a 1/3 of the price. After this I'd never buy anything from Rutland. I'd be going to buy a well know and trusted brand of blade first. And then seriously look at and question how I'm using the tool and whether I'm doing it correctly and appropriately! 😉
Yes, it definitely struggles with this and needs guidance. Anything that involve geometric sense seems to be a crux, unless it's very simple. I've also just found something else it's rubbish at. Ask it to build a website and it'll build something very good in the blink of an eye. I asked it to re do a couple of adverts I've got in print media - the output was just terrible, so bad I'm actually speechless so I just said I'd go and do it myself! I've been finding the bliss of work with Claude & Claude code and it's like magic. It's also funny how Claude restricts Claude Code, admitting the constraints have to be very clear so that Claude Code doesn't try to do something 'helpful' - it just makes me laugh 😁
That does look amazing!
Well, out of luck on burning too many tokens right now as no Fable any more: The US government, citing national security authorities, has issued an export control directive to suspend all access to Fable 5 and Mythos 5 by any foreign national, whether inside or outside the United States, including foreign national Anthropic employees. The net effect of this order is that we must abruptly disable Fable 5 and Mythos 5 for all our customers to ensure compliance. Access to all other Anthropic models will not be affected.
I'm still being nice! And new workflow in place. Discuss with Claude, produces prompt for Claude Code, check output using Claude, approve/disapprove, back to Claude Code to Implement and commit or re-prompt. Scary thing is that Claude Code shows the token burn count as it's chugging away.
Yes, that's exactly it. It drives me a bit mental, especially when it then compliments itself on the code it's created itself! And when I find a bug and it's going round in circles there's been a few time when I said we've had this problem before, haven't we! It then goes oh yes, found it! and then just sorts the instance, rather than the class, like it's telling me. And also the handover docs are absolutely essential otherwise it goes even further off piste! Fair comment. I certainly used to get the simple easy response that's only half there until I set up my full project with memory, files, and instructions. And as you say most people won't get past the initial crude request. That's not helped by the abundance of YouTube content telling people how they can build a multi-billion dollar no-code app in 5 minutes. People will try, then find there's a steep learning curve, especially if they've never built software before, and give up after another 5 minutes and instead try the next no-code promise for $10k/month passive income and on to the next one. I was quite shocked when I realised that I'd been working on my project since last August and it's June already and I've gone through some right challenges in that time. Now, progress is amazing and I haven't needed half a million quid and a team of software developers in Bangalore (or maybe these are the real homunculus hiding in chat?), so that's incredible for as you say 20 quid a month! And by all accounts they're promising reduced token prices now too!
So the absolute bonkers thing here is that last night I had a chat with Claude about my outdated and pretty rusty approach to development. And I got some feedback. Here are some examples: First Claude butters me up: "Your domain knowledge is exceptional and it shows. The handover documents are some of the best I see....." To let me down gently: "You build features faster than you solidify foundations....." "Bugs are fixed reactively rather than by closing the class." "Session continuity relies heavily on handover documents rather than code structure." "The "upload current files first" pattern is correct — but you sometimes skip it." "You could use me earlier in the design phase. Most sessions seem to start with "here's a feature, let's build it." You'd get more value from 10 minutes upfront: "here's what I'm thinking, what are the architectural consequences?" "The emergent style has worked well to get here. The shift you probably need now is from "make it work" to........which means investing a bit more in the boring stuff: " Now I'm building out a modified set of prompts combined with project references to hand the responsibility of dealing with these things to Claude, with Claude's help! It is genuinely amazing. What I've also done is gone through with Claude the best pattern to use with handover between the reasoning and coding tools - so it takes it beyond just the coding. It totally blows me away how powerful this can be. Just a shame it can't help me physically in my day job!
You've reminded me that I need to set up a Pi for some sensor logging. Carry on trying though - you'll get the outputs you need eventually and its worth the effort. When I first tried, I nearly gave up coz I thought it was all crap and I got rubbish outputs too. Now I'll get me coat as I'm now starting to hijack @Pocster's thread 😲
Go on, how did you learn? Did you do the child process which is just chuck in what seemed like a prompt, get a load of garbage and then refine, or did you study prompting first (I can probably guess). Personally I read a few articles copied and pasted some example prompts to see what happened, got bored and just went in to play and found my way that way. I'm sure I've still got a whole load to learn but tbh outputs are generally pretty on point most of the time.
On this, I should probably mention that I acquired a balance dysfunction following a bad infection. The legacy of this is that I can't spend vast amounts of time in front of a computer screen ever since. So being in front of a screen and trying to read and write code has been virtually impossible for me for more than 2 decades. The advent of AI for doing this has just opened back up a world that had been lost to me. I never really loved coding and always preferred the design and specification of systems but I still used to create stuff. And now I can do that again without horrible symptoms. So from an accessibility perspective it's rather marvelous too.
I was listening to Linus Torvalds speaking about AI during an interview where he was saying how useful AI is and its power to identify bugs and vulnerabilities. But he also said that AI wasn't capable enough to fix them - that needed humans. I kind of agree. The problem is that AI can only look backwards to harvest stuff that already exists and then regurgitate that - it doesn't have any imagination at all and certainly can't see a path or opportunity ahead (I think this is a limitation inherent in the cognitive models used to develop the llms and will probably also seriously limit the function of agi unless they change tack) . To develop this functionality, just imagine the size of the required context window, we'd be building a data centre or 2, if not more, dedicated to each and every user.
Perhaps I should rephrase to considered commenting that is helpful rather than just crap coming out of the numb brain of a programmer who's had enough and bored!
That probably sums it up rather nicely. It's random. Having been out of the game for over 2 decades, I'm not massively surprised by the short cuts and poor approaches to design that I'm seeing in programming generally. I've pulled Claude up on that a few times but we have a chat about it and then take an informed decision. Probably one of the best aspects to using AI for coding is the commenting. As long as the prompts specify the extent of commenting, it is miles above what you usually find with human produced code because it takes a lot of effort to think about and formulate comments if you're the programmer. So this makes life so much easier. Generally though, it's actually one of the good things the AI does and I'm blown away by what it can do, even if it does have its moments. You just have to learn how to compartmentalise the work, slicing it up into smaller components and formulate your prompts.
That's one of the reasons I stopped using DeepSeek as although it produced some very good code - it seemed to particularly like Python but its approach to UI was a it questionable - code & file management was very painful.
