dangti6
Personal Information
  • Location
    Taunton, Somerset
4597 profile views
dangti6's Achievements
Regular Member
Regular Member (4/5)
48
  1. We're currently having a block paved path laid as part of a driveway replacement and it's dawned on me that the path runs along the full width of our property and at some point in the future we're likely to have a Fibre to the Premises (FTTP) connection and it would be a shame for it to be disturbed. There's no other route that would avoid the path being crossed. Pin kerbs/edgings go in tomorrow, so I'm too late to mail order some ducting (believe Openreach use a 54mm duct) and nowhere locally as far as I can tell sells that ducting or similar. Well, at least Travis Perkins, Bradfords etc certainly don't list fairly small bore ducting that's not a full reel. Fortunately I'm a bit of a hoarder and I have a metre long length of 110mm waste pipe kicking about. I was wondering if it's worth running this length of pipe buried underneath the pin kerbs whilst I have the chance, in the hope that Openreach (or whoever else) would run their ducts through my supplied 'tunnel'? I can't see why they wouldn't accept that route Vs lifting the paving. Alternatively, has anyone else laid anything available from the major sheds such as B&Q/Wickes for this purpose with success?
  2. Last year I started laying some slabs for a path. I don't have a cement mixer so I mixed the mortar bed by hand in a wheel barrow. Due to various time restraints I did this on several occasions when I had a couple of hours spare to lay half a dozen slabs or so. So far this year my free time has been taken by other jobs more desirable than mixing mortar by hand. I have kept an eye out for a cheap cement mixer and often either beaten to it or left with adverts for mixers that appear to have been dredged from a canal. I don't want to buy new and hiring isn't really viable as I really don't get the time to throw full days at it in one go. I was watching a YouTube video recently where a builder used a paddle mixer for a small concrete job and I figured this could be an idea for my situation of small batches. Naturally I am looking at £30 Chinese paddle mixers and his machine was likely a decent one. So the question is, have any of you guys had experience with mixing mortar with cheap paddle mixers? As an emergency or more frequently. The adverts do state they mix concrete and mortar as well as paints etc, but then they would say that. Realistically if it begrudgingly lasts to do a number of mixes and is junk after, i'll be content.
  3. Interested to hear how you get on and will be watching for any advice as I am contemplating doing my own block paved driveway. First I need to sit myself down and think honestly whether I have the enthusiasm as well as the back/knees to pull it off as it's not a quick job. I'll start by measuring the area and looking at the cost estimates for a firm to come in and do it. That usually motivates me, such as it has for you here. Are the interlocking blocks with the porous gravel infill any more susceptible to weeds than the standard ones that lock together with sand?
  4. I screwed a wall plate to a 254 x 146 x 143 UB which had a flange thickness of 12.7mm. I used these which have a long enough cutting end bit to go through material of that thickness and possibly a bit more - I have the box somewhere and I'm sure it listed the max material thickness
  5. Check the crates data sheets, loads to choose from for trafficked areas and can take many many tonnes.
  6. Might be misinterpreting your final statement, but why not use crates? The older method of filling a soakaway with material reduces the volume and therefore requires a larger 'hole'.
  7. Don't suppose you'd be fortunate enough to have photos from the for sale listing showing the original fence/boundary line at all?
  8. I used RequestaPlan which was about £24 for the 3 plans required.
  9. Did you ever see the report?
  10. I rubbed it down with 180 grit on a block which took the marks and pencil off and applied the first coat at the weekend. Another brief rub over, again with 180 grit this morning and gone over with a second coat of osmo door oil. Beautiful stull to use, it really is. I was particularly careful to not apply too much oil, and laid it off before a wipe over with a microfibre cloth to take any excess off. The first coat was dry in less than 24h at ~13 degrees.
  11. I have just had a tickle with some 180 grit - the finest I could find within my stash and it's working ? This is my first oiling job so it's all new to me. Am I right in saying 180 is too rough? Doesn't feel like it is. I'll take a trip out and get some 240/320 if that's the way to go for a better finish.
  12. I have an unfinished oak veneered door which I need to slap some osmo oil on. There are numerous pencil marks from hanging it. Also a few marks which appear to be grubby or greasy finger marks from handling which I don't want to enhance with the oil. I ran some white spirit over the short edge as a test, and it didn't shift the pencil. I tried an eraser but the pencil is quite deep in the grain. I'm yet to sand, but as it'll be a light key sand I don't think I'll have much luck there within the grain either. Acetone is one contender. I'm reluctant to try it though for fear of it staining. Anyone had luck with it on similar? Unsure if it's more suited to solid timber rather than thin white oak veneer.
  13. Thanks guys. I will add the kitchen storage units beforehand and leave the water/waste side of things 'til a later date as they are a 'nice to have' purely as there are feeds I can extend from an original extension behind the garage.
  14. And I guess that's my concern - could they have reason to believe a garage containing a utility function is an attempt to use the room for a habitable purpose. Let's face it, I could make some further improvements to turn it in a bedsit and let it out if I was so way inclined (devils advocate and appreciate that's probably more of a planning issue and I am not concerned about planning). I guess I am hoping that would be a no, and you'd have to have made other material improvements to suggest that was the case and the inspector would only look at what was presented to them against the application and simply not concern themselves with a tumble dryer and water/waste source in view when they come to do final checks on a garage.
  15. Building regulations, in the sense that the structure is a single skin building without insulation etc as it’s a garage and built to that requirement. My fear is/was that on the off chance that a BCO could perhaps class the extension as habitable under the guise of a garage they could play hard ball. Does sound like I am worrying unnecessarily, so will probably be assembling some kitchen units later!
