Gary68
Everything posted by Gary68
I believe a 400L tank should have 2 sensors 1 towards the bottom and 1 towards the top, there is a setting in the hot water menus to set the cylinder to std or large. Large will mean it uses the bottom sensor if its set to std it will be using the top sensor only and only heating the top third of the tank. If you have enough HW this probably isn't the case but worth checking, the std and large settings are under DHW recharge in the menu
I have an Ecodan with a 210L tank we only heat once a day to 47C and don't reheat, its fine for 2 showers and a bath, with a 400L tank you definitely don't need to reheat during the day.
ASHP advice on buffer tank / heat store and more
Gary68 replied to Joyosa's topic in Air Source Heat Pumps (ASHP)
I think you need to go back to basics get someone to work out the heat loss for your house or do it yourself on the heat punk website then you can determine what your options are. Have you any idea why a 56kW heat pump was installed 19 years ago? It could be massively oversized like boilers are, you may only need something half the size or less. Why do you have a 300L buffer tank they are usually installed to keep oversized heat pumps happy with good flow rates which leads back to the first question. -
Its nearly 20 years old, at the end of its serviceable life, are you not better off starting from scratch with a modern heat pump and redesigning the heating system as best you can. -
In terms of internal noise and monoblocs I noticed you mentioned Mitsubishi, they don't have external pumps so the main pump and the noisiest one will be in your house, so I would avoid, I speak from personnel experience.
Ecodan - room temp auto adaptation and multiple zones
Gary68 replied to BEJB's topic in Air Source Heat Pumps (ASHP)
Agree with John sounds like its plumbed incorrectly and its not getting hot as its just pumping the return water from zone 1 that is already cool. If you ramp up the flow temp to 45C and the ufh start to get warm then that would confirm it.- 23 replies
- ecodan
- auto adaptation
(and 3 more)
Mine does that too, I think its just the app. Do you have a mitsubishi preplumbed cylinder, if it was for 2 zones there should be 4 pumps in total, 1 for the primary circuit, 1 for each zone and 1 for dhw. If you turn both stats on to call for heat you should have 2 pumps lit up with lights if they are the std grundfos pumps that are usually on the cylinder- 23 replies
- ecodan
- auto adaptation
(and 3 more)
Are you saying that you can only heat zone 1 or zone 2 at once, or is just that you haven't got the thermostats calling for heat at the same time? If its the former then something have been wired up incorrectly. I have UFH downstairs and rads upstairs they are on separate stats and both can call for heat independently or together they just have different pumps for each circuit.- 23 replies
- ecodan
- auto adaptation
(and 3 more)
If you unscrew all of the actuators I believe that should open all the circuits as the actuators hold them closed so if the actuators aren't wired in correctly or they fail, then they will just stay closed.
Ecodan and Mitsubishi PUMY cooling ena
Gary68 replied to AhMario's topic in Air Source Heat Pumps (ASHP)
What is calling for 'heat', you may find that you need to increase the temperatures on your thermostats to call for heat which will tell the heat pump to turn on and then cold water will circulate round the system. That's how it works with my air to water heat pump. -
Heat pump cylinder without the heat pump...
Gary68 replied to Antonb182's topic in Air Source Heat Pumps (ASHP)
Its an Ecodan, flick DIP switch SW2-4 to on, reboot system, cooling now available in heating menu select flow temp and away to go. -
Actual water temperature from the tap?
Gary68 replied to puntloos's topic in Air Source Heat Pumps (ASHP)
Mine is set to 48C and I can just about hold my hand under it continuously, so it sounds like you are a lot lower than that if the bath is just warm enough, at 50C you get burnt in 5 mins. Also depends where the temperature sensor is in your tank if its not towards the bottom a lot of the tank won't be at 52C -
Programming a Mitsubishi heat pump (peak and off-peak rates)
Gary68 replied to Garald's topic in Air Source Heat Pumps (ASHP)
The Melcloud app is easy to program, just choose your unit, go to timer, I add in the start of the off peak time and till it to run at a fixed flow during the winter. The flow temp can only be set from the main controller not the app. Then at the end of off peak I tell it to run change back to WC. In spring and autumn, I still run it at night but only in WC mode so 32C rather than 45C in winter. At this time of year it probably won't come on till the next off peak period, so no peak use. -
Do I need relays to switch pumps / zone valves etc
Gary68 replied to Tim S's topic in Air Source Heat Pumps (ASHP)
Agree with Johnmo I have an ecodan I had an extra ufh pump fitted and a wiring centre with actuators and zoned thermostats. 5 years later it’s all redundant never needed in the first place all the actuators are disconnected all zones open all the time ufh pump is turned off water flows round quite happily when the heatpump is on. Probably £500 of waste if it was designed correctly in tne first place -
8.5kW Ecodan - expected cost for annual service?
Gary68 replied to Happy Valley's topic in Air Source Heat Pumps (ASHP)
£200-£300 is typical in southern England -
3kw is exactly what most immersions pull that would my first check if you have one. The switch for ours is in the understairs cupboard and my in-laws turned ours by accident had me puzzled for a while.
For a rough estimates divide by 2900 so yours would be 6.3kw so your looking for a 7 or 8kw heat pump
Mitsubishi ecodan better control system
Gary68 replied to eniacs's topic in Air Source Heat Pumps (ASHP)
If you have the MELCloud app you could do it. There is a timer function and you can set it to heat or cool at any time or day. -
Post a screenshot of the front screen of your controller and your heat curve sounds like either the heat curve is wrong or you are running at a set temp and not weather comp
It defrosts less at -7C so increased running time at higher flow temps
My heat loss was calculated at 7.7kW and they installed a 8.5kW Ecodan, it works well at the -2C design temp it has to run 24/7 to keep the house at 21C but works right down to the -7C temps we saw this winter with no noticeable impact to internal temp. I believe this is because the MCS heat loss survey is probably conservative so we have a bigger buffer (no pun intended) in the heat loss than calculated. The bigger issue with Ecodan's is that if you have the Mitsubishi preplumbed cylinder then they come with an awful LLH and a whole host of pumps and to maintain warranty they have to be filled with glycol. The other issue with Ecodan is that the primary pump is not located within the outside unit, its installed internally within the house so depending on the location can cause a noise nuisance, especially at night. The Ecodan also cannot modulate the flow rate itself to maintain delta T. In saying all that its run flawlessly for 5 years, has a reasonable COP of 3.5. Would I buy one again, no, I would give Vaillant or Daikin a go if I had to change.
Just to clarify the Melcloud app doesn't calculate COP. Its shows an estimate of power consumed and heat generated on a bar chart that you can estimate COP from but its not particularly useful, as there is no data other than the bars and its an estimate. Where the app is useful is seeing what the flow and return temperatures are doing for the last 24 hours so you can see how its cycling on and off. You can use it to turn the ASHP on and off remotely and change room temperature if you are using the main controller to control temperature. You can also set a schedule for heating and hot water and change from fixed flow to weather compensation modes but you can't change the flow temperature specifically.
There is an installation video online there is only 1 place it can go, turn off power to FTC, remove cover (4 screws), plug in, put cover back on.
