elite
    1
elite last won the day on August 5 2021
elite had the most liked content!
Personal Information
  • Location
    Shropshire
elite's Achievements
Regular Member
Regular Member (4/5)
59
  1. If they have confirmed the case has been closed, I would just crack on
  2. I've not had any issues with the velcro in the heat, and I haven't needed to remove the velcro as I leave it on until the next time we have some warm weather TBH if you're looking for a decent finish, I'd do as @Nickfromwales suggests or get proper split unit put in
  3. As a "temporary" solution I have a 4mm sheet of arcylic held by velcro onto the casement, the velcro doesn't look great but it does the job until I get around to renovating the bedroom and coming up with a more perminant solution like having proper insulation or even proper AC. I haven't had any issues with the weight of the hose
  4. I would guess at 4 or 8, more in a densley populated area If you can get a clearer shot of the connections on the bottom you might be able to get a better idea That said even if there is capacity at the pole, there might not be upstream Good luck with BT / Openreach - very frustrating to deal with
  5. For the header I would use 2 of your studs nailed together rotated on end as they will be much stronger in that direction than the floppy way
  6. Hard to tell from the pics, but I would say bumblebees - certainly doesn't look like honey bees Bumbles will only use a nest for one season, so this was probably last year and they shouldn't return Pic 2 of the second post, looks a bit like the base for a destroyed wasps nest
  7. Have you considered insulated metal panels? They acheive a decent span, though the detail around the gable doors might be complicated
  8. Recessed magnetic contact sensor / reed switch as used in alarms - depends on your doors / windows, then just need someway to make that info available to your blinds
  9. elite
    Rats!
    Chicken keeper here, if you have chickens, rats will try and move in. If your neighbour will cooperate get them to minimise the amount of food available - treadle feeders are good, but take a bit of training for the chickens Locate the runs they the rats are using and place bait boxes across them, make sure you wear gloves when handling to avoid making them smell of humans. I've found the grain bait much more attractive to the rats than blocks, but of course make sure non-target species can't get access. Keep bait topped up for at least a week after they stop taking it. Rats are naturally cautious so it may take some time for them to trust a new food source or strange new objects in their run. If you can find someone with a good ratting dog, they will have the time of their life
  10. CT1 or some similar sealant on the outside where the glass meets the rubber? But will only ever be a temporary fix
  11. Not a sparky... I do grey as neutral and black as CPC (both sleeved at both ends to identify) Don't forget to make sure your armour is connected to CPC too and you have continuity - wiska do some nice clamp bars I'd use wagos to connect the cores, but do check they are rated to at least 32 amps (in your case)
  12. Yes I would want an upstand, EPDM should be lapped up the upstand and then flashing applied on top
  13. Perfect - thanks
  14. I'd probably go with a tile backer with SLC - marmox claim 40 tonnes / m2 when tiled, not sure about LVT. They say you can use any thickness board, unless onto floorboards which then has to be minimum of 10mm. So thickness really depends on how much insulation you want vs how much height you want to lose You probably only need 3mm SLC, unless the floor isn't level A much more painful option would be to dig down and get a decent amount in the slab
  15. I've had an EV charger installed at the renovation, I am currently with Octopus so was looking to swtich to Octopus go, however they are not offering it as the smart meter is not communicating with them (I don't think it has ever successfully sent or received data) - the location has terrible mobile connectivity I understand they have to try and make it work, but I was wondering if anyone has had experience with this? Seems a bit rubbish if I can't benefit from smart tarrifs just becase the DCC network coverage is crap
