Jymmm
Everything posted by Jymmm
Monitioring hardware/software recommendations
Jymmm replied to Dam0's topic in Air Source Heat Pumps (ASHP)
Good point John thanks -
I'd like the open energy stuff but is very expensive. I have a shelly EM in the consumer unit which monitors the power to the heatpump and i can access the data in home assistant. Has anyone put a shelly inside the heatpump to monitor flow and return? Would need to 'borrow' a few mV from the heatpump power. -
What thermostat and dew sensor are you using Dave? Interested to know how have you implemented as ive been thinking of doing the same with home assistant.
Yes a wet car will inevitably be put in there as the car charger is inside the garage.
The dew point was 11degC yesterday with the previous week more or less constantly below 0 so it’s an extreme shift. There is a DPC and the floor beam & block + screed is sealed with epoxy. it’s just difficult to know which way to go. Vent or seal it up. cars are parked in it too. do piv systems work in this situation ?
Hi all, Has anyone solved or vastly improved the garage condensation issues that plague detached garages/workshops this time of year. Is it just a case of improving ventilation until the problem goes away? I have vented eaves and ridge which means the boarded out roof space has very little condensation. But at floor level the tools, bikes, engine parts etc are all dripping.
trying to increase the heat in the two flow meters with the red arrow. 3l/m looks to be the max i can get it too with most of the other loops having a max range all the way to 5
Thanks for the replies - that makes sense. Trying to increase the floor temperature in that room as its a few degs lower compared with the other loops. The pipe lengths are unknown to me unfortunantly and its the furthest room from the manifold/pump. I'll have to see what can be done with the pump speed. Thinking about it backwards; In terms of efficency with a heatpump & buffer - Would it ever make sense to match the other loops to the worst performing loop? I.e adjust the other loops to give the same surface temps as the coldest floor surface making everything the same.
Hi All, I've always struggled to set the flow on the above flowmeters. I've only just noticed that they sit alot higher than the others on the black plastic threaded part. Is this why i can't increase the flow? How do i fix this? How would i know the type to replace if i need to get another one Thanks
How to control an Ecodan with UFH manifolds?
Jymmm replied to ADringer's topic in Air Source Heat Pumps (ASHP)
Do you have any details on the logic controller you have. Is it something you have DIY'd ? I'd be interested in one for my system. -
ESP Ecocent Air to Water Heat Pump inside?
Jymmm replied to ashthekid's topic in Air Source Heat Pumps (ASHP)
Used for DHW only. Standard newbuild 300mm wall with 100mm insulation. Having to change the Magnesium anode every year is tedious and expensive (£60 and ESP the only place to buy them). Documentation isn’t that good either - I have no idea how to set the anti-legionella function for example. It’s also a little bit too noisy for my liking. That said I’ve had no problems with the end-product – hot water is fine. I also don’t mind the constant ventilation even if it’s reducing the heating efficiency of the house. Have they quoted you a price yet as it would be interesting to know. Factor in the £200 odd for the annual service and anode change (and good luck finding someone easily to do the job). If I needed to replace it I’d have a look at something like the vaillant aroSTOR depending on price. Care to elaborate? -
ASHP 'Service' - what exactly are they doing?
Jymmm replied to gc100's topic in Air Source Heat Pumps (ASHP)
In theory they should clean out the filters. Measure the refrigerant levels and pressure. Check over the settings and make sure everything is running optimally Eye ball for any gas or water leaks. I've had mine serviced a few times but i'm not convinced its value for money. I now just do it myself - I don't measure the gas but i do data log the power consumption stats which would tell me if it was running funky. Check if your warrantly necessitates the service though. -
This an interesting idea - have you used this yourself ? Looking at their website a 'shelly 1' with the temperature addon module and a DHT22 sensor and you have the basis of a smart thermostat.
No issues that I’ve encountered yet. I’m at the first year service point so plan to inspect/change the anode. Trying to get through to ESP to purchase a spare is fairly painful. Has anyone managed to source their own? -
I have an Ecocent 300l, happy to answer any questions you may have -
It could be that the thermostat needs to be calibrated. Check floor and wall temperatures with an IR thermometer (a very usefull gadget with underfloor heating)
Are air source heat pumps noisy
Jymmm replied to Technoheckno's topic in Air Source Heat Pumps (ASHP)
What do you mean by ‘MI,s’? Thanks for your info - I think I definitely need to try longer flexi -
how long are your flow and return lines between the pump and the house? Mine is actually quieter outside than it is in the room it's attached to so something isn't correct in my installation. -
mines sat about 50cm away from the wall (100mm stone, 100mm insulation, 100mm block, dot & dat 12mm) its the reverberating sound from the water pump that's heard mostly which isn't great. Yet the water pump is hardly noticeable outside. -
I'd have to check, is there any rule of thumb with the length? -
I've got a distillery ?
Jymmm replied to canalsiderenovation's topic in Air Source Heat Pumps (ASHP)
It's pipe insulation. Insulate all that pipework inside & out. -
Kingspan Kooltherm or similar. I have a setup similar to yours with no blending valve too. Zone thermostats should be set to protect the floor max temp too. What flow temp are you running from the heat pump? -
We have ours placed outside our living room which i would not recommend. Installed with flexi hoses but still getting alot of 'mechanical' noise transferred into the room from the water pump and compressor. Its almost noisier inside the room than outside the house. The heat pump is only used for space heating. Acoustic Enclosures exist too -
Old post but did you have any luck with this issue?
