Everything posted by Pocster
The latest suspect ; these seams . Too wet inside to retest . Tomorrow is rain and storms so no good either . Have expanding foam so will build a little perimeter barrier around this area then fill it up .
Episode 19 - “ that muvver fecker “ Story recap : After witnessing extreme violence and scenes of a sexual nature Pocster decides to take matters into his own hands . The mistress threatens to announce their relationship to the world - causing tension . Pocster concludes the only way is forwards towards his inevitable fate …. Rotten tomatoes rating : 99% Average journalist rating : 2% Isolated further - and made it leak … That gate post asphalt needs a closer look once I get the Ali decking supports up
So kind , so thoughtful 😊
More pages , more content , more fun . Like a Netflix series with too many episodes only to get to a drab finale . Suspense and wonder are the key !
(expletive deleted)ing forum
My best mate chatgpt says it’s ok to use to form a temporary holding perimeter. Any humans agree ??
Watched some flat roof leak finding videos . What I REALLY want is a method to make anywhere on the roof a water tight container around areas to isolate it . For example if I took all the decking up around the skylight and put a 100% water holding barrier around it - that would be magic . But how ? . Can I use expanding foam on asphalt to build a retaining barrier ??? 🤔
Took up more decking . Looks like the surface water does run round to that skylight . But it can’t be flooding around it . Also of course the leaks coming in under the roof not over the upstand . But it’s another possibility ( perhaps roof asphalt damage during installation of glazing ? ) .
So it’s something around this corner . Took up the decking . Nothing obvious . Those overlapping flashings filled with ct1 look fine . Next test once it’s dried up and leaking stopped to flood this corner but not up or over the flashing - just the actual roof . Not sure what else to try .
Still leaks 🫤
Vent Axia - Unit Noisy!
Pocster replied to richo106's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Does sound like the bearings . Have you checked the condensation drain and make sure there’s no sitting water in either side ( that can cause it to make a different sound also ) -
No it doesn’t but you must have faith in my skills
lol ! Bit late for me - but that does seem a good price !
Money spent . Fair play to RicherSounds did a good job . In the cinema room he asked if I wanted a drink . Did ask for a beer . But that was a no . So r6000f II left and front mains 500c II centre 4 x 40m for surrounds s121 sub No 3800h in stock . Went online to Peter Tyson and ordered that . Demo’d the Sonos arc ultra also . Significantly better than my q990c . But a true surround system was even better - he could only do 5.1 - sounded great though . Now I just tell SWMBO it all cost £800 .
Ok , more than 1 drop . But not quarter of a bucket . So now to fix that 2nd overlap . There are no more overlaps on that run , so I hope this is it ….
Ok . It still leaks - 1 drop and a bit damp . I was hosing that area - I believe ( guess ) that spray from that maybe also hitting this overlap . So will ct1 that and repeat tomorrows test.
Hosed the wall on Max for 10 mins above that flashing overlap . The inside was slightly damp to touch from previous rain - so it makes judgement harder . But ! , 20 mins later nothing obvious inside ! . So will leave ( assuming it’s fixed ) as inside should be drier tomorrow and repeat . Looks promising though !
Yeah , £95 a metre wire that’s what I use on my vac .
I was wondering if it took standard stereo music and made it ‘better ‘ . Gaming will be atmos etc . Getting excited now - as will the salesman be dreaming of his commission
Off to spend money almost for certain tomorrow….
Auro - 3d , yah or nay ?
Finally filled the flashing overlap with ct1 as dry today . Will hose and test tomorrow
So the Klipsch rc50 is a newer centre speaker than the rc52 . Thats an intelligent naming convention !
A soundbar is a great easy step . My Samsung q900c does a very good job if budget and space are limited . I’ll be selling it if interested ….
