Pocster
    29
Everything posted by Pocster
  1. B o l l o c k s
  2. Only issue is to get the feed from the mixer to the shower head will require hep20 joints . I was trying to avoid using them to reduce the chance of leaks - though to date no hep2o fitting has ever leaked . So I guess shouldn’t worry about using them ( they will be inaccessible)
  3. Floor to head approx 213cm
  4. Shower head fixing has a ball joint so can tilt - this look ok ?
  5. Nasty Cludge to get shower head fitting on other wall . Wall single stud and fitting needs to be recessed . Access from rear not possible .
  6. My rainfall can’t be central on its wall - but I don’t think that will matter . My controls on the other wall are ‘offset’ to the right. If I move the hose outlet I could put my riser central .
  7. I’m considering this !! . The hand rail riser is in the centre of the wall on that side ?
  8. Fair enough . I guess my perception is it’s all on the same wall ...
  9. Yeah I considered that . But won’t it look wrong ??
  10. Ah ! I most of dozed off before I reached that bit .
  11. Roper Rhodes - so shouldn’t be cheap kak . Yep stem thingy fitting in the bsp to hep fitting . Think from memory ( I’m remembering well today ! ) it was you that pointed me towards these things some time ago . They are neat . But I can’t see how you dismantle a stem from a hep fitting as the dismantle key won’t fit in !
  12. Googled it and suggestion was 183 to 203cm Might push it up that extra 70mm ..
  13. Well I clicked ‘next’ 28 times on your life story thread . Erm , not sure what I’m meant to be looking at . Brought back a nostalgic tear to my eye , the good old days before CV and brexit . When life was simpler and grout lines were uneven .
  14. Trays not in . But roughly height from floor to shower head is 190cm . I’m 6ft 1” so seems low too me . I can reposition it a bit further up - gain maybe 70mm That too low ??
  15. @Nickfromwales told me to do it like that ???
  16. Yeah . I got to 10 and thought that was ridiculous. Seems ok now - will leave overnight and see .
  17. I forgot how much brass fittings like to leak . Each fitting should come with its own roll of ptf tape . Maybe in the distant future all mixers / taps etc. are hep20 ready ... ?
  18. Possibly . Did seem to go on a bit . I swore at it ; still dripped
  19. See ! I do listen and retain sometimes .
  20. Decided therefore to test the shower head . Indeed opening the manifold did seem to alleviate the knocking . One thing I noticed is that with the shower set to fully off a small trickle still runs through the shower head . Can’t see any obvious adjustment for this ...
  21. I’ll order some 135 see if that helps Shower head can’t be ceiling mounted as ceiling on an incline
  22. Sorry you’ve lost me . The fitting on the mixer is bsp to hep20
  23. Just vaguely remember @Nickfromwales saying not to attenuate flow with the manifold . Not on site at the mo - but possible manifold tap not completely open ...
  24. It’s all curves up until the mixer as it’s a single run per feed with no joints .
