Everything posted by Pocster
Yeah I thought of that . Don’t want to lose PV generation 😂😂😂😂 It’s strange how I ( we? ) think . I’ll be absolutely determined not to draw 1kw at peak or miss 1kw of PV ( pence ) . Yet go and buy a latte for 3 quid and not even think of it 🙄
I’ll try it then 😁🤣👍
This isn't going to work again tonight!. SE full, PW full and exporting! 😎 So PW bound not to touch the grid. I really do need a cloudy day! I was thinking though. I'm 99% certain I can get the PW to take from the SE constantly i.e. PW stays at 100% as it drains the SE ( ignoring any PV ). This I *think* might be better especially for winter. As some of us seem to think; even if both go to charge from the grid what happens when one becomes 100% full. I'm pretty certain as there's been some evidence to support it the PW would start taking from the SE ( after all it would make sense to charge from a source not the grid if it's available ). This would then potentially mean only the SE is grid charging and PW just stealing. SO! - if PW constantly tops up from SE then during winter off peak SE will always have less charge than PW as PW depletes it. If they both go to the grid to charge PW won't steal from SE as SE is not 100%. So both in theory will charge from the grid. SE should reach 100% first ( it seems to charge at 3.68kwh and it's capacity is 9.7kw ). So at a certain point SE will be full; PW will see it and start charging from it. But I think in this particular case as both SE & PW will be near to 100% it doesn't matter. Also as SE needs less than 3 hours to charge I could start its charge 1 hour after PW begins. Thereby the chance of it getting to 100% and PW stealing a significant quantity is reduced. That theory/logic/nonsense make sense?
Nope nothing . Did think it was strange - assume you’d get something . Failing that the rather expensive tool station bracket would do ?
https://www.toolstation.com/rawlplug-sinkfix-premium-basin-fixing-kit/p53802?utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&mkwid=_dm&pcrid=&pkw=&pmt=&gclid=CjwKCAjw3K2XBhAzEiwAmmgrAhDLJfWAroklDASD6i--4ff40RqeN7KS5uAdWSS27VdIFTUeUbjXxxoCLpUQAvD_BwE&gclsrc=aw.ds ??
People of the masses ! What fixings should I use to get this basin on the wall ? Assume some bracket/ thread type thing it hangs on ???
Well ! The test was inconclusive. Looks like PW didn’t take from the grid . Will leave it as is and see what happens tonight.
Of course I will …… not !
@Radian you know I said I didn’t understand why the PW doesn’t just drain the SE as it see’s it as PV . Well , I think it can . Which might be exactly what I want . Been fiddling with these settings … ( page 1 ) https://www.solaredge.com/sites/default/files/storedge_charge_discharge_profile_programming.pdf
Only fly in the ointment might be that PW decides not to charge from grid as it had a ‘good’ PV day … who knows !
I changed a parameter to avoid the charge / discharge cycle . SE can only charge from solar or discharge . At 00:30 it will change to charge from grid . At 04:30 it will change back to charge solar or discharge .
Things of note . PW max output is 5kwh sustained as is SE In reality this isn’t possible. As PW sees SE as solar and inverter max is 3.66 then max output is 8.66kwh . Anything above that will take from the grid . In practice this isn’t an issue ; just make sure total house load doesn’t exceed that ( unless there is PV also ) .
Not sure what you mean . House total load is around 7.5kw as we speak . SE is discharging as is PW ( PW can only do 5kwh sustained ) . No evidence of grid draw nor yo yo between them . This I have seen before and fits in with my understanding of how I expect it to work . How “they” know - not a clue 😁
No . It’s being used . PW and SE are both charging EV…
Some faffing ! But got it all going for the test . SE is set to “ discharge to maximise export “ - the alternative didn’t seem to work ! . So SE is giving up max juice to supplement PW to charge my EV as it thinks it’s exporting ….
Actually; I forgot - SWMBO is WfH - so we will start emptying batteries far quicker than I imagine 😁
So much for “ poor PV generation “ today . Everything’s 100% full and exporting . I’ll wait until later until PV is low . Then charge EV .
I just wanted to say yes so that I felt useful .
No idea ! First thing is PW and SE charge from grid simultaneously ( no EV charging ) . I’m emptying my PW and SE deliberately into my EV to force them to charge from the grid . I would assume EV charging is simply seen as a load to PW and SE like everything else …..
FAKO = (expletive deleted)ing Awful (C/K)rap (from) Overseas
I have the official real mc coy . You have to be careful as even when fully clipped a wire can occasionally pull out ! . I use on mains and stuff because I’ve got big nuts and ain’t afraid of dying . You bought cheap sub standard shite so you deserve an electric shock . Enjoy ( it’s a slow night for me so need to post any crap )
