vfrdave
    1
vfrdave last won the day on March 13 2017
vfrdave had the most liked content!
Personal Information
  • Location
    co down
vfrdave's Achievements
Regular Member
Regular Member (4/5)
91
  1. Hi, I need a plasterer for a small job (well my dad does) to wet dash a block wall. My dad and myself built it but don't fancy the plastering bit. Struggling to get anyone that is interested in a small job, and isn't a 'Facebook Diyer/small job man' Recommendations welcome.
  2. Yes should have an inner black sleeve that slots into those guides on either side.
  3. All the same block, there is a variance in the colour....hence they recommend selecting from multiple packs at a time to ensure it is randomised.
  4. Still not finished but this what I have done with Allan block/colinwell
  5. Colinwell is another option for interlocking blocks.......easy DIY
  6. Colour matching pipe sleeve/pipe cover
  7. I bought a Collingwood H2 Sense to replace an existing spot in a recessed canopy at our front door. The front door is out of sight of main lighting system when exiting house, and for those not shown to the door they exit in the dark. Anyway tested light on a 3 pin plug and it operates as intended. Wired it into desired place and the damn thing is either permanently on (if switch bypassed) or just operates as a switched light. The pir doesn't seem to have any effect. Can anyone shed any light (no pun intended) before I loose the plot.
  8. It would appear that your DHCP up pool has changed from 3rd octet 188 to 56. Given the subnet address your wireless bridges are on a different network than the PC. Is the switch a simple unmanaged switch? Ie no config on it, just plug cables in and it works?
  9. Yes to the electrician doing data cabling, unless you are going all out with a bespoke home automation solution.
  10. I had hse in NI shut my site down a few years ago for no scaffolding and fall deck. Rightly lectured me to all of the issue and stated professional scaffolding was required. Problem for me was a sprawling bungalow was still too small a job for most companies to be interested in. Long story short, system scaffolding erected by me and inspected by hse for signoff was all that was required. No scaff tags etc asked for.
  11. More likely this one https://www.screwfix.com/p/mcalpine-mactun-2-tundish-with-self-closing-valve-15-22mm-x-1-1-4-/589JJ?tc=QA4&gad_source=1&gclid=CjwKCAjwh4-wBhB3EiwAeJsppH5gst-d9cNqO9Z6RB6RKNRk93fa6TM-DvVf98bnwQKCHjSOi02FgxoC4lMQAvD_BwE&gclsrc=aw.ds
  12. I'm confused on this one. My understanding is as follows:- - A land registry map in NI likely shows you own to the middle of the road, particularly if rural. Given mid-ulster I assume that is the case. - Roads service have rights to maintain what constitutes the highway (hedge to hedge, fence to fence etc), by virtue of some ancient law. This feeds into maintaining sight lines over someone else's land ie a sight line exists and you just need visibility over it. - to get a new access for a property over land owned by someone else, for it to be long-standing and stand up to dispute should be a legal agreement for right of access. What confuses me is that the lay-by is yet to be built, but will be for access to your additional site. Therefore what is proposed above will end up being a shared access? In the country in NI this can be limiting for mortgages etc
  13. Apologies not weedol but SBK https://www.diy.com/departments/sbk-systemic-concentrated-weed-killer-0-25l/5012042022501_BQ.prd
  14. I have this in my what will be garden and it is a nightmare. Glphosphate hasn't done much for it in my case, however weedol rootkill plus has worked to a degree but it keeps coming back!! @Sarah29 any particular variety/type of lime?
  15. I remember debating about my air valves and other multiple things on ceilings like smoke and co2 detectors being independent and stressing about how it might look etc. Some wise head on here, maybe @Nickfromwales told me, after a while you won't even look at them never mind notice they are there, how true that is.
