Onoff last won the day on October 28 2024
Onoff had the most liked content!
About Onoff
- Birthday 05/12/1967
Personal Information
About Me
I'm going to die in a cold, unfinished house and be eaten by rats! I can only dream of being thermally & financially insulated!
Location
Fromunder, Kent
Onoff's Achievements
Advanced Member (5/5)
6.4k
Wasn't there a tin mine where they switched the pumps off and everything flooded? A couple of weeks later the price shot up as in it would have paid to keep it viable. By then though the damage was done etc.
In some cases justifiable in spades: https://www.sovereignmagazine.com/article/cornish-mine-redmoor-billion-critical-minerals
All it needs is Keanu Reeves and a tuning fork! We could of course mitigate a lot of this by having a state body with real teeth to force insulation upgrades of existing housing stock. Why not instigate punitive taxation for those not complying? (I'd be f***ed). Then ensure proper compliance by those doing it. Let's get away from the mass builders using one good test result for the whole estate and cowboy heat pump installers fitting them to inappropriate buildings.
Australia has 160 billion tons of thereabouts of proven coal reserves. Reckon the Chinese will be running coal fired stations for a good while yet.
It's almost as if they're suggesting a lot of public funding issues are caused by uncontrolled immigration and the costs entailed supporting/dealing with it. Weird eh?
Just loving my EV 😉 Jump in and look and the range. Then turn the heater setting up and watch the range drop before you've even moved. Green washing BS.
I think I'd lay down a permeable weed membrane then do gravel grids so free draining. How uneven is the grass exactly?
I believe you in that I've a similar issue and feel your pain. Since this crisis we've not used our oil for heating. Very uncomfortable is how I'd put it. We only use the oil for hot water. It's genuinely often colder inside the house than outside in the sun. As I write this, waiting to go to work I'm huddled under a blanket in the lounge. With the house so cold you can feel a constant, gentle cold breeze across bare arms. No doubt coming from multiple gaps in the building fabric. It's pretty miserable tbh. We've put a curtain across the lounge and run a 2kW electric heater in there. It eventually takes the edge off after a good few hours. My lad has taken to showering at work. Luckily my daughter is at uni. SWMBO and I huddle in the lounge at night like one of those old couples living in fuel poverty. I'd put oil, gas, coal even wood in the "high quality" as in high temperature heat bracket. ASHP is "low quality" as in low temperature heat. It can and does work but you're building fabric needs to be proofed against heat loss and the effects of (cold) wind washing. I can't imagine how long, if at all, it would take for that to heat your big old stone wall fabric house at the same time compensating for the losses. Yes I could have the oil boiler running at full chat and it'll eventually bring the house up to a reasonable temperature. A wood / coal fire would be great to get some instant heat. Is there a room in your house where you could in effect do all six sides of the "box" with seamless, internal wall insulation as in no gaps in the insulation where the walls, floor, ceiling meet? That and have good windows and door. Think of it as a thermos flask. The better the insulation, with no gaps, the less loss through the walls of the flask, the hotter it feels and longer the heat stays in the flask "room". You would then need less heat to heat it. You would still need to be careful.ref ventilation.
Ah! Didn't realise he was in foreign climes.
Does it have a current transformer attached to the incoming house mains live or some other "intelligence"? As in what stops it drawing too much and popping the main house fuse when you've the electric hob and shower on full chat then decide to charge the car? Mine has a current transformer at the house connected to the EV charger via 37m if Cat-6 that also connects the charger to the internet router. I did the bulk of the work myself on mine and then the sparks came along and certified it. Mine's a company supplied charger. So I have an Electrical Installation Certificate for the charger. On top of that I'm pretty sure there should be a form done for your DNO, in my case UK Power Networks, the form being a Low Carbon Technology Application Form. Not saying it won't all work etc but things to be aware of. I'm on 22p/kWh. Looking to get a smart meter to take advantage of lower night time tariffs.
Similar situation here where my mains water comes up through the footings / slab then into a suspended floor space. I ran the MDPE water pipe in a blue corrugated duct: I then rolled a bit of perforated, galvanized sheet and wrapped the exposed section of duct within the suspended floor space: Like this:
Recessing elec conduit in floor for floor plugs?
Onoff replied to Great_scot_selfbuild's topic in General Flooring
I'm thinking the duct/cable should be at least 50mm deep if in a floor and of course RCD protected. -
Cheap stainless steel pot scourers scrunched in and foamed. Crushed, broken glass is good. Round here it was de rigueur to lay bottles down if building a shack, smash them all and cast the slab on top. Just to stop the tunnel bunnies gnawing their way through.
Galvafroid, MIO (micaceous iron oxide), black bitumastic etc. But then I'm old school.
What are the best prices for (EWI) EPS insulation at the moment?
Onoff replied to oranjeboom's topic in Heat Insulation
It was @MarkyP I believe. He still looks in on here I think:
