Drew1000
Everything posted by Drew1000
Hi, Hope you guys can help. I am intend to build an outdoor gazebo which will be 4M long by 3.6M deep. The roof will have a ridge with hips at both ends. The roof will be constructed from 6 by 2 C24 framing and covered with 11mm OSB. The plan is to use Cambrian lightweight tiles from Redland which weigh 17kg per square metre. At a rough guestimate of 16 square metres that would work out around 270kg then add battens, guttering and felt for a ball park 320kg. My rafters will be spaces at 600mm centres along the roof and for ease of calculation would mean 8 rafters either side at approx 2M. At approx 3kg per metre that works out at around another 50kg. So unless I have forgot something I think we are looking at approx 400kg. My intention is to have 5 supports, 3 along the rear and one at either end at the front to ensure plenty of walk space at front when entering with a ring beam around the top also in 150mm by 150mm. The posts and ring beam will be of Larch. My question is. Will the beam across the front spanning 4M be suffifient to hold the roof weight without sagging or would I need some sort of steel support. Thanks in advance. Regards
I am going to build a summer house which will be used as a Gym. It will have a concrete base inside but I am intending using self leveling compound as the finished floor. Grateful for any advice on which make to use from those with a bit more experience. Will not be pouring for a few months until weather is a bit warmer and the building is wind and watertight.
Face brick water absorption below DPC advice required
Drew1000 replied to ruggers's topic in Brick & Block
Yes another vote for engineering brick.. Only solution in my opinion -
Vapour Control Barriers are breathable. DPM is not and should not be used as a VCL
Have built a few timber frame houses now and always use acoustic insulation in the internal partition walls as this helps with sound reduction. Always use sound block plasterboard (Blue) on ceilings and outside of bathrooms and toilets. No reason why you could not use the sound block on all walls. If I was doing a house for myself it is something I would definitely consider. It is more expensive and heavier to work with but you only do it once. I have not had any feedback on houses being noisy that I have done but it does depend on many factors like type of floor covering in upstairs etc
How to keep Exposed Frame Dry In Winter
Drew1000 replied to bob the builder 2's topic in General Structural Issues
Depends on the way the timber frame is going up depends on what would be the best option. It makes little difference to the kit if it is bare timber, it will dry out in time once you get the roof and windows in. If you can get the walls up and then roof on and felt fitted without having to floor the 1st floor then that is a bonus. If you need to floor the first floor then you can use some temporary arrangements for the guys to stand on inside or use something like Egger protect P5 "Anti-slip, moisture resistant and hardwearing structural chipboard flooring that can be exposed to the elements for 60 days. Suitable for new builds, refurbishments, renovations and timber frame construction projects." But make sure they use the D5 glue and plenty of it between the joints (12 bottles recommended for a pack of 66 sheets of 22mm floor boards) The kit normally comes with a vapour protect layer which covers all the window and door openings which you can keep in place until the last moment but is a bit of a pain for preventing light in and you need to stop the joiners just cutting them out willy nilly during installation. If its a bungalow then some of the above is obviously not applicable. -
Moving from self-build insurance to standard house insurance
Drew1000 replied to jamieled's topic in Self Build Insurance
When we re-mortgaged from a self build loan to a normal mortgage on completion the mortgage company insisted on sending a valuer out to assess the finished house (we had to pay his fees). This was all part of the mortgage service and quite normal. I have house and contents insurance at the moment which is only £149.00 a year from Policy Direct and covers me for build costs of £500,000 and £75,000 contents. I have seen other policies which quote a £1M as the basic re-build costs. -
Just a thought Dave. Looking at the wall between the family room and Lounge there looks like a sliding door. Given where you have the seating (which looks like the natural place for it) it will severely restrict a wall or floor area to put a tv on for both rooms. (Maybe you are not having any). Just a thought to ponder and its your house at the end of the day.
- 9 replies
- building warrant
- electrics
I have just finished two new builds and put in some round pin 5A sockets in the corner of the lounge/living room controlled from a switch coming into the room. That way you can get some table or floor standing lamps controlled from light switch. Much better than the Blackpool illuminations that a lot of spots give off however retain some form of main/bright lighting for whenever it is necessary. I also use two way and intermediate upstairs outside the bedrooms to enable anyone coming out a bedroom at night to turn on/off the upstairs hall light. As for sockets a good rule of thumb is a double in the corner of each room. Agree about tv area if having a tv unit with other boxes like sky Q, games consoles etc put 2 doubles behind unit. For upstairs and downstairs hall its a good idea to have one for a vacuum cleaner and don't forget about the Xmas tree area which might need extras. Hope that helps.
- 9 replies
- 2
- building warrant
- electrics
Hi, Just finishing a new build with my son who has just moved in. he wants to build a garden room approx 8M by 4M to use as a gym. He has some pretty heavy equipment that he would like to put in so was thinking about a concrete floor probably around 100mm to 150 thick. The plan is to install an air conditioning unit that would provide both heat and cooling. Question I have is should I put something like 100mm celotex/Kingspan insulation under the concrete floor or would this be a waste of time and money. The walls and ceiling will be well insulated. Thanks in advance.
Thanks to all who replied to this thread. Conclusions are that if cost and time are not important then 2 hinges should suffice. On this occasion the doors are not that heavy so don't think paying the extra material and labour costs are justified. hope I am right in the long run. Regards
I am about to get my internal doors fitted which are 2040 by 826/726. None are fir doors and they are 40mm thick. Question is - should I get 2 or 3 hinges fitted. grateful for any advice from joiners who do this on a regular basis.
I am about to install new kitchen and would like to put led strip lights under the worktops along the front edge. Worktops are not specialised granite or quartz, just normal laminate. Kitchen layout is L shaped with 2M by 1M island. Plan is to put lights on L shape and island. kitchen forms part of an open plan kitchen/diner. Grateful for any advice from anyone who has done something similar and any dos and dont's. Also any advice on ratings, colour ie warm or cool white, recommended suppliers etc. Any advice much appreciated. I am an electrician so will be doing the job myself, just not fitted these lights before so looking to the self build community before I start. Regards.
I need to build two steps from front door of new property. This is not the main disabled access entrance. Does the first step need to be level with the finished floor level inside or can I step down onto first step. Also what is minimum width of steps, was thinking 300mm.
I am plumbing first fix in self build which has timber 50mm by 37mm battens which form the service void where cables and pipes (15mm) will run. Question is how do the pipes which are plastic exit through the plasterboard to service sinks, toilets etc. Is it just a case of knocking/drilling a hole in the plaster board and feeding them through or is there normally some sort of interface box/fitting used. Appreciate any advice from those who have done this type of build before. regards
Has anyone got experience of how to isolate free standing bath taps. looks like there is not enough room to fit isolation ball valves like a normal tap. Appreciate any advice on fitting these kind of taps (apart from don't ?)
Engineering Flooring in Bathroom and En suite
Drew1000 replied to Drew1000's topic in Wood & Laminate Flooring
Thanks all for the replies. Intend showing the client the replies as back up for for own views and see if they still want to go ahead with this. Again many thanks for replies, much appreciated. -
My client wants to put engineered flooring throughout the upper floors including main bathroom and ensuite. There will be UFH in both these rooms so a floating floor with 10mm gap around perimeter for expansion required. I have my concerns about finishing up against the shower tray, fixing the toilet pan to the floor and the height difference between these rooms where they transition to adjacent bedroom and hall. Anyone any experience of this scenario and the problems it throws up. Am I being a bit negative about the whole thing. Appreciate any views from those with previous experience/history of this type if installation and any tips or advice they have. Regards
Was watching a you tube video by The Candleman which was very good in painting a new build property. He used acrylic primer for door frames and oil based undercoat for skirting boards. can anyone please explain the difference and any pros and cons and also where water based undercoats come into the equation (if they do). Apologies for ignorance on paint but thats why Im here posting I guess.
Hi, Does anyone have ball park prices I should expect to pay per door for the following in new kit house. I will be supplying all the material so just a labour cost required. Fit door frame 220 by 33 dressed red pine Hang Pre finished Door and fit door furniture ie Jig tech handles, hinges and locks (to bathrooms and ensuites) A few of the doors will require a Perko door closure as well. Only doing upstairs at the moment so 8 doors in total for now Thanks in anticipation.
I am looking to fit a 3 zone programmer to control my heating and HW system. They seem to vary quite a bit in price. Any recommendations from those you guys may have used in the past.
Hi, I am currently building in the West of Scotland. I will have a gas boiler situated inside a relatively large cupboard in the utility room and also a gas hob in the kitchen/diner. Realise I need a Carbon Monoxide alarm in the vicinity of the gas boiler but do building regulations require one for the kitchen where the gas hob is situated.
No limit on height just the size of the house, a 250L should be plenty big enough
