colin7777
Personal Information
Location
Nofolk
colin7777's Achievements
Member (3/5)
5
Need to now order door linings and can see there are trenched and untrenched, I can see the difference between the two types. The trenched linings are quoted as 838mm, the doors we are looking at are as 838mm 2ft 9in. How safe is it to guarantee that doors and linings will be actuate enough to fit correctly. I don't want to trim the door as they are prefinished If I bought untrenched will they have to be trenched or can the uprights be butted against the top lining. Looking at primed linings.
My architect has shown the DPM on the Beam and Block floor, then running up and over the course of bricks and then the sole plate placed on top of the DPM. To enable this the DPM will need laying before the timber frame is installed, if this is the case does the DPM need to be protected to stop it getting damaged while the Timber Frame is being installed. What is the best solution or am I not understanding his drawing ? Colin
Our approved planning application did not raise any questions as to any turning circle. We once built will be living on an un-adopted private road and have no way to drive in and out in forward gear. The highways had no comment as it is a private road, all they commented on was the access from private road to public highway as to if it was suitable for an additional 2 cars capacity. No guarantee that this is the same view in all planning departments.
More 4
Hi All, Sorry tried to remove but couldn't find how to do that so just taken out content.
Just received a quote for block and beam floor and wondering if it is a fair price. 150mm deep 'T' Beams total of 28 beams total length of 75 metres £837.85 100mm wide Slip Bricks quantity 207 = £72.45 Medium Density Lightweight Infill Blocks 53 square metres £537.95 Total £1448.25 Exc VAT Install price £895 Exc VAT Thanks Colin
- 1 reply
Would appreciate if anyone can recommend 2 or 3 block and beam supplier, if possible close to Norwich. Thanks Colin
Since initial post I have been shown this option where the Block and Beam are mounted within the I section of the Steel Beam, has anyone else built their foundations this way. Anyone see any problems with this method.
After many months working through Timber frame companies and foundation options we are very close to making a decision but just looking for some views / clarity as to the foundation / floor insulation. We have to have piles due to being by a river that will have a steel ring beam. it is a small one and three quarter property approx 13 metres by 6 metres and looking to use block and beam. We are not aiming for a highly insulated house, walls have an estimated 0.16 U, and ceiling has an estimated 0.13U. The timber company can supply the floor insulation and have quoted 90mm Kingspan kooltherm K103. Does this seem a sensible thickness to get a balanced U value for the property, would there be any benefit to increasing the thickness for comfort / cost benefit. The bedrooms are on he ground floor and we have decided not to have UFH . Their diagrams show that the timber frame would be placed on two layer of bricks which I guess takes up the insulation and screed height, I was expecting the timber frame to be fixed directly to the screed / Block and beam. One thing that puzzles me is how everything is going to be held down if brick is used: Timber Frame Sole Plate DPC Brick Beam and block Steel Ring Beam Any ideas, comments, experiences, do's and don't or any views on any aspects welcomed. Colin
Council Tax
colin7777 replied to dnoble's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
How do they calculate the council band that the property falls in as I understand current tax bands are based on property prices many years ago. -
Plastic vs Copper pipes for radiators
colin7777 replied to Raks's topic in Central Heating (Radiators)
Maybe a non starter, but has anyone taken pipes through the inner service void area on external walls and then out through the plaster rather than up through the floorboards. This would make it so much easier to keep the floor clean and less chance of the pipes being bashed with the hoover. -
Trying to design kitchen layout, looking at having eye level Oven and Grill in tall unit but struggling to design where it should go in relation to Hob, Tall integrated Fridge/Freezer and Sink. All diagram I can find only show the typical triangle and never shows where to put an eye level oven. The area is 3500 x 3100, no windows just one roof light approx where I have put 'RL' in diagram. Not the best of diagram below but hopefully it shows shape of area. Wondering if to wrap any units round where it opens to the lounge. Ideas appreciated Outside Wall ________3500___________ 3 | RL 1 | This opens 0 | into Lounge 0 | |_______________________
Ground floor for bungalow: joists better than a slab?
colin7777 replied to Dreadnaught's topic in Timber Frame
How does Concrete slab compare to Beam and Block on cost, weight and insulation. We have a ground floor area 12 metres by 6 metres, it needs to be on piles with a steel ringbeam as water has to be able to flow through in a flood situation. The gap from soil level to ground floor level will be approximately 500 mm, so looking for best solution Thanks Colin
